Is there a way to permanately delete archived projects in A360.
Solved by Bud_Schroeder_ADESK. Go to Solution.
Hi Martin,
Thanks for posting your question to the forums. After you archive a project you should see the option to delete that project. Mouse over the project on the left side and you should see restore and delete options.
NOTE: Once you delete it, you can not get it back, it will be gone.
Hope this helps and have a great day.
