I came into the office this morning & recieved a call from an irritated client (prior to logging into my PC) as it seams that my A360 account has been uploading drawing files that I had downloaded the previous day.
This occuered another time but when I had opened drawings through Autocad & the modified drawings were uploaded - I fixed this by disabling the check box in online options.
A360 seems to be uploading files that I havent opened please help.
Solved by BrettWright. Go to Solution.
Alistair,
In your system tray at the bottom lower right of your screen you should see the Sync icon with a small orange arrow pointing downward. Clicking on that should allow you to do the update.
Let me know if that isn't present for you.
Brett
no there is no "Product Update available" arrow - but there is a sync icon which is spinning.
these are the options available to me:
Brett, I have rebooted & the same version (no option to upgrade)
I am have not "clicked" to the best of my knowledge to upload any files, I have been added to a Project on Autodesk 360 & this is where the Issue is coming from.
Autodesk 360 is uploading files that I have downloaded, back up to the Server I downloaded them from.
Please look at the screengrab image, I work for eCubed Building Workshop & I have not opened the files listed BUT apparently I have uploaded them to the Project Drive.
The Syncing is constant - & because of the number of files associated with this project I am struggling to keep up in terms of what I have downloaded.
Why is there not an update file I can download & run ?
Ali,
In the log files that you sent, we see that sync is failing to delete 26 files (over and over again), prior to it trying to upload/update them again. That action fails, so then sync just keeps trying to upload them over and over again, hence the neverending sync.
Can you manually delete the list of 26 attached below from your online 360 site, and then see if that makes a difference?
Just right click on the A360 icon in your lower system tray, then select Launch Autodesk 360 Web. Lets see if deleting them from there first helps the issue. It might not, but lets at least try it.
