Hello
Just a minor irritation with an error message from Autocad 360 (see attached). Has any one else got this problem?
Hi Bud
Thanks for the response. I'm using AutoCAD 2014. I've carried out a quick search of the local store and there does not appear to be any file with the extension .xml in there. In my amateur attempt to resolve the issue myself I looked at the locations within the C:\___\Appdata\Roaming location et al for any file names RegistryData.xml renamed them by placing an appending an underscore to the front of the file name. This has not stopped the error message. In addition I’ve set AutoCAD 2014 to not sync any settings to the cloud. Again this has not worked.
Kind regards
Justin Carr.
Hi Justin,
Thanks for the update. Can you also let us know what version of A360 Drive sync client you are running? While logged into A360 there is an icon in the system tray. Right click on it and select preferences to see what the version is. You may want to make sure you have the latest version of the sync client on your system.
You can also get the 5x version from the following WEB Site.
Let me know how this goes and what version you are running. You may need to re install the Desktop Sync client to clear this error.
Thanks again for all the updates.
