Thanks Bud,
The same problem regarding Inventor Decal features not exporting also applies to;
- A360
- Navisworks
- Showcase
- 3DSMax
But for some strange reason it was patched to work with Design Review 2013, allowing .DWFx files to show Inventor Decal features.
Previously I've logged this issue via Autodesk support, but again I will log it on the Idea Station.
Karl
Hi, thanks for this helpful thread. I have a Inventor model that I need to show on my mobile. But it seems everyway I try, I can't get the decals to show.
If the show in DWFx, does that mean if I open my model in A360 using the DWFx, will the decals be supported?
Thanks for your help
I tried all sorts of file types including stl, stp, igs, 3ds, and more.
The best results were from dwf files. Not all of the decals showed, but some. All of the decalls that didn't show instead had a reflection view, and when you zoomed in, you saw the cars and things from the picture used for effect. So I'm not sure what differenciated some decals to others, but for some reason, some worked and some didn't. But I couldn't find anyway of having it fully viewable with all decals.
I had the same problem with the reflection picture showing... I found out that if u go into the appearance browser and click the pencil on the color to open the appearance editor, you can change the finish to flat/matte and your decal should show on A360. My finish was on gloss when it would show the reflection image with the cars on it... oh and the type might have to be wall paint... im not sure but thats what worked for me. I just duplicated gray and changed the color as needed
