I am using Bldg Design Suite Premium 2014, and am getting constant sync errors from A360 via tray icon. It cannot sync without have the red delta w/ '!'. It happens on both my work computer (Win 7 x64) and home laptop (Win 8.1 x64) both with the same 2014 software. I have the most recent service packs, and am using A360 version 5.2.3.1000.
This problem started happening around the middle of last week and has finally annoyed me enough to ask if anyone else has the same problem.
Solved by Bud_Schroeder_ADESK. Go to Solution.
Hi Charles,
The error looks like it's comming from Customization Sync. Can you try going into the Options dialog and then the Online TAB. Then unchecking the "Sync my settings with the cloud" It looks like one of your customizatino settings is not happy. See if unchecking this stops the error from returning.
Thanks and let me know how this goes.
Some more details:
In order to rename the folder, I had to disable Autodesk 360 from starting with windows (right click tray icon -> preferences), then shut down computer, wait 60 seconds, and restart. Otherwise the folder would appear to be locked by explorer.exe.
Here's the folder itself:
Problem is back...with a vengeance. I recently reformatted both my work and home computer, and the constant sync errors are back. I have followed my own steps above, and even went as far as overwriting my online settings from AutoCAD with newly configured local settings.
After overwriting my online settings with local settings, I notice AutoCAD seems to hang on uploading settings (found by clicking on account portrait in the top-right corner). On my home computer, I go to sync my settings with 360, select discard local settings and use online settings, and the screen flashes for a second while AutoCAD reloads the default settings, not what I had customized on my work computer. Previously (before reformatting and overwriting my online settings with local settings) both computer would at least load the same online settings, albeit with sync errors as described above.
I'm beginning to think my A360 account has corrupt customization files. I'll try again with a different A360 account and see if that works...
Hi Charles,
I've forwarded this on to our sync team to engage on and review the history of this item. They'll respond back to you directly here on this thread.
Stay tuned, and hopefully we can get this figured out quickly for you.
Hi Charles,
We would need some additional details from you to investigate this issue.
Can you please send me the version of A360 Desktop (Formerly known as, Autodesk 360) installed on your machine?
I found in one of your previous posts that installed product has "A360 version 5.2.3.1000" but, i would like to confirm it once again.
In addition to that, we may need to look into the log files of A360 Desktop to identify problem.
You can send me email with these log-files at chandan.singh@autodesk.com.
Here are the instructions to retrieve these log files:
Chandan
Chandan,
I am still running A360 version 5.2.3.1000.
I have sent you the log files as you requested.
I used the solution that I previously posted to re-create the Autodesk Sync folder from C:\Users\*\AppData\Local\Autodesk by renaming the previous folder with "Old" at the end. It is from that old folder that I zipped the log files, not from the new re-created sync folder.
I haven't had the sync error pop up since re-creating, but I'll keep watching it. I haven't used Autocad much since re-creating it, but will be doing so today.
Hi Chad,
Just a quick update that the team is still working on this, so we'll continue to be in touch as i hear more back from them.
Please let me know if anything has changed on your end.
Action for Chad: Can you please let us know if you're still having these "constant sync issus". We actually discovered an issue in the backend that has since resolved itself which we think might have been causing this so please let us know as soon as you're able.
Hi Chad,
Did it happen once, and now all is ok, or is this a continuing issue that is still not working correctly.
Can you please send over any screenshots of errors you're receiving, and the log files too, that Chandon requested the last time please? See the prior posts from him.
I'll then send them over to the Dev Team as soon as i receive.
Sorry for the inconvenience.
