This message has been reposted as per request of A360 Support. Thanks
Hey Autodesk,
Due to a series of macros and functions we run on Visual Basic and MATLAB, we need to be able to better control the path to our Autodesk 360 files. For esample, Autodesk 360 automatically installs to a sub directory under the windows user name:
C:\Users\username\AppData\Local\Autodesk\Autodesk Sync\Cloud\username\Projects
We would like to change this so that our Autodesk360 folder resides only on the C:\
Also...
Can we please get rid of that space in the directory name "Autodesk Sync?" It's killing us. Again to link our Autodesk 360 folder to our macros we need to eliminate that space in the file name. Can we rename that folder to "A360" or "AutodeskSync???"
thanks so much,
-Justin
I guess the problem is that the project file resides on the server.
If you cannot path 360 to the server then you cannot completely sync back up.
For example your xrefs and shortcuts are all out of sync. A lot of opportunity to lose work.
A thumb drive is still the best way to take a project with you on a trip or to work at home.
Just my opinion.
Is my concept of 360 wrong??
JHB
