Area :: Header
Interested in making Indie games?
Register for a Meet the Experts webinar with Digital-Tutors today!
Discussion Groups
XSI SDK
Member
taro_1
Motion Trail
529 Views, 17 Replies
09-02-2012 08:29 AM
Hi.
I made a MotionTrail Tool.
You can see and edit trails of animated objects.
If you'd like, try it.
how to use
1. install addon.
2. register a shortcut key or a script button.
3. activate the tool, and select an animated object.
motiontrail.zip
Please use plain text.
Distinguished Contributor
langdon
Re: Motion Trail
09-02-2012 09:53 AM in reply to: taro_1
tried to install in softimage 2013 sp1 x64bit and in the plugin manager the dll is marked as red.
tried to assign a custom hotkey in the keyboard mapping panel but i cant find it at all.
something is wrong? would like to try it.
thanks
Active Member
svsh
Re: Motion Trail
09-02-2012 12:09 PM in reply to: taro_1
goooood
Member
taro_1
Re: Motion Trail
09-03-2012 08:23 AM in reply to: taro_1
> langdon
Thank you for the information.
Do you use other "StartAnimation" or "StopAnimation" plugins?
I use these names as Event Plugins in this plugin.
So, if you already use these names, my plugin will be error.
I changed my event names into other unique names.
If you use these names, please try version 1.1. You can install.
But if you don't, I have no idea...
Could you tell me Script Editor's Error Log?
I think you can see logs, when you try to install addon.
anyway thanks.
> svsh
Thank you!
motiontrail_v1.1.zip
langdon
Re: Motion Trail
09-03-2012 09:12 AM in reply to: taro_1
Thank you a lot.
I managed to get it to work, i select the animated object and start the MotionTrail the trail appears and i can select the points but how can i move them? No handles will appear, if i swtich to move tool i lose the motion trail.
I cant move those points.
edit: nevermind i had to reboot softimage, everything works now. Thanks a lot!
New Member
piotrekmarczak
Re: Motion Trail
09-03-2012 09:26 AM in reply to: taro_1
Hi taro,
can you upload it to si-community.com? this forum is dead
good work!
New Member
Procedural
Re: Motion Trail
09-03-2012 09:46 AM in reply to: taro_1
どうもありがとうございます!!
http://procedural.tumblr.com
Member
taro_1
Re: Motion Trail
09-03-2012 09:55 AM in reply to: taro_1
> langdon
I'm relieved to hear that.
Maybe you know this.
But I explain for others.
This plugin doesn't have handle like manipulator.
You can pick points immediately.
> origin
Thank you.
I want to do it, but I can't register si-community.com...
oh, but somone posted it instead of me. thanks!
> Procedural
どういたしまして!
Leendert68
Re: Motion Trail
09-04-2012 02:32 AM in reply to: taro_1
@taro - Did you already try logging in at the si-community? An account named "taro" has already been registered and activated there. You probably didn't get any activation notification, but, sadly, that's sort a known bug in "our" forum software...
PS - If you still experience difficulties logging in, please send me a Private Message here, so we can try to sort this out!
Member
taro_1
Re: Motion Trail
09-04-2012 09:38 AM in reply to: Leendert68
Thank you, Hirazi Blue!
I could enter si-community!
It was my fault.
Pleae look at the reason in si-community.
I'm embarrassed.
