Wiretap
New Member
philippoeser
Message 1 of 2 (1,552 Views)
python error
1552 Views, 1 Replies
01-24-2011 07:12 AM
Hi there,
trying to get Python bindings to work on windows (but can't...)
here is what I did (tried to follow WiretapClientSDK.pdf as best as I could):
(1)  installed python 2.3.5
(2)  installed boost 1.42
(3)  copied every DLL from "boost_1_42\lib" to "python23\DLLs"
(4)  downloaded WireTapAPI-2011-1295
(5)  copied WireTapAPI-2011-1295\lib\opt\WinNT\x86_32\WinXP\MSVC_80\libwiretapClientAPI_dynamic.dll to "python23\DLLs"
here is what I get:
ImportError: dynamic module does not define init function (initlibwiretapClientPI_dynamic)
I am willing to compile WireTapAPI-2011-1295\samples\wiretapPythonClientAPI.cpp myself but would appreciate an example compiler commandline/settings as my tries have been unsuccessful. this will also be a target later (we use py 2.5/2.6 here normally).
Anyone got this to work?
Thanx in advance for your help
Philipp
P.S.: the python examples in the PDF always import "libwiretapPythonClientAPI" even though the generated library is "libwiretapClientAPI_dynamic.dll". Is this outdated? I tried importing "libwiretapClientAPI_dynamic" for the above error...
Also renamed that DLL to "libwiretapPythonClientAPI" and tried importing that (which doesnt seem to make a difference)
New Member
centro_systems
Message 2 of 2 (1,503 Views)
Re: python error
02-14-2011 04:00 AM in reply to: philippoeser
I'm new to Wiretap and Python. While I try to setup a windows box to run these, I ran into the same problem you have.
The zip file I downloaded is wiretapapi-2011-1295.zip
in its WINXP folder, there are:
libwiretapClientAPI_dynamic.lib
libwiretapClientAPI.lib
Is it mean to be missing a libwiretapClientAPI.dll ?
seeing this line in all the sample python scripts:
from libwiretapPythonClientAPI import *
I tried to rename the libwiretapClientAPI_dynamic.dll to match the name. But with the same ImportError.
ImportError: dynamic module does not define init function (init<withWhateverNameIType_CaseSensitive>)
Can anyone give us a working example?
Thanks in advance.
Maurice
You are not logged in.
Ask the Community
