Has anybody got a lisp program to generate a xref report. I know about designcenter and use it a lot but I would like to be able to send the report a text file. Unfortunately I do not not always use the latest Autocad versions and so would need it to work from versions from Autocad 2009.
Thanks in advance
Thanks in advance
As a "demo"...
(defun c:demo (/ fn lst of) (vl-load-com) (vlax-For blk (vla-Get-Blocks (vla-Get-ActiveDocument (vlax-Get-Acad-Object))) (if (= (vla-Get-IsXref blk) :vlax-True) (setq lst (cons (vla-get-path blk) lst)) ) ) (if lst (progn (setq fn (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME)) " - XRefs.txt" ) ) (setq of (open fn "w")) (foreach l lst (write-line l of) ) (close of) (startapp "notepad" fn) ) ) (princ) )
HTH
Henrique
Here's one I wrote many, many moons ago:
(vl-load-com) (defun c:BatchFindXref (/ *error* _WriteXrefData acApp acDocs oShell oFolder path dwgs filePath dbxDoc file doc ok ) (princ "\rBATCHFINDEXREF ") (defun *error* (msg) (if file (close file) ) (if oShell (vlax-release-object oShell) ) (if dbxDoc (vlax-release-object dbxDoc) ) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it ) (princ) ) (defun _WriteXrefData (doc) (vlax-for x (vla-get-blocks doc) (if (= :vlax-true (vla-get-isxref x)) (progn (or ok (setq ok T)) (write-line (strcat dwg "," (vla-get-name x) ".dwg," (vla-get-path x) ) file ) ) ) ) ) (if (and (setq acApp (vlax-get-acad-object)) (setq acDocs (vla-get-documents acApp)) (setq oShell (vla-getinterfaceobject acApp "Shell.Application")) (setq oFolder (vlax-invoke oShell 'BrowseForFolder (vla-get-hwnd acApp) "Select folder to search:" 0 (+ 1 64 256) ) ) (setq path (vlax-get-property (vlax-get-property oFolder 'Self) 'Path ) ) (setq dwgs (vl-directory-files path "*.dwg" 1)) (setq filePath (strcat (vl-filename-directory (vl-filename-mktemp) ) "\\Batch Find Xref Report_" (menucmd "M=$(edtime,$(getvar,date),YYYY-MO-DD)" ) ".csv" ) ) (princ "\nWorking, please wait...") (princ) (setq dbxDoc (vla-getinterfaceobject acApp (strcat "ObjectDBX.AxDbDocument." (substr (getvar 'acadver) 1 2) ) ) ) ) (progn (setq file (open filePath "w")) (write-line "Directory Searched:" file) (write-line path file) (write-line "" file) (write-line "Host Drawing:,Reference Name:,Saved Path:" file) (foreach dwg dwgs (cond ((not (vl-catch-all-error-p (setq doc (vl-catch-all-apply 'vla-item (list (vla-get-documents acApp) dwg) ) ) ) ) (_WriteXrefData doc) ) ((not (vl-catch-all-error-p (vl-catch-all-apply 'vla-open (list dbxDoc (strcat path "\\" dwg)) ) ) ) (_WriteXrefData dbxDoc) ) ((write-line (strcat dwg ",Unable to open drawing. ") file ) ) ) ) (princ "Done.") (if ok (vlax-invoke oShell 'open filePath) (prompt "\n** No surfaces found ** ") ) ) (cond (filePath (prompt "\n** Unable to create \"ObjectDBX.AxDbDocument\" Object ** " ) ) (path (prompt "\n** No drawings found ** ")) (oShell (prompt "\n** No folder selected ** ")) (acDocs (prompt "\n** Unable to create \"Shell.Application\" Object ** " ) ) ) ) (*error* nil) )
"How we think determines what we do, and what we do determines what we get."
