Visual LISP, AutoLISP and General Customization
richie.hodgson
Message 1 of 10 (387 Views)
xl coordinates to table
387 Views, 9 Replies
03-19-2013 02:07 PM
Hi, I am in a bit of a hurry, I need to draw a table with point number, easting, northing, elevation for a lot of points and need a lisp to read the xl spreadsheet and draw the table, can you help.
Richie
richie.hodgson
Message 2 of 10 (360 Views)
Re: xl coordinates to table
03-19-2013 05:21 PM in reply to: richie.hodgson
I have written the atached lisp but it is reporting an error can anyone fix it for me
Richie
*Expert Elite*
JGerth
Message 3 of 10 (357 Views)
03-19-2013 06:27 PM in reply to: richie.hodgson
post your sample text file please.
richie.hodgson
Message 4 of 10 (354 Views)
03-19-2013 06:29 PM in reply to: richie.hodgson
Here is the text file
Richie
devitg
Message 5 of 10 (311 Views)
03-20-2013 04:20 PM in reply to: richie.hodgson
Your firts error is the WCMATCH wilcard use
      (prompt (strcat "\n" LN))
;;;"0\t415013.38\t790131.48\t0"
      (cond
        ((wcmatch LN "*`,*") (setq CD T)); CD = Comma Delimited
;;;;the COMMA char is a reserved wildcar , in this case it will return T , despite it have no comma
 ;;To use COMMA as pattern it need a reversed quote `
        ((wcmatch LN "*`\t*") (setq CD nil)); space delimited
;;Your file is not space limited , it is TAB limited
;; browse the lisp help for wcmatch
        (T (prompt "\nDid not recognize format.") (quit)); otherwise
      ); cond
Also you have a miss )
	(setq pt2 (list 0 0))
	(Setq pt3 (list 0 25));_ miss parenthesis
	(setq pt4 (list 150 25))
I  have to chek it further more , it is the start.
Feel fre to contact me , if you want to.
devitg
Message 6 of 10 (307 Views)
03-20-2013 04:52 PM in reply to: devitg
see more observation at the lisp , and see how the dwg it is do.
richie.hodgson
Message 7 of 10 (302 Views)
03-20-2013 05:39 PM in reply to: richie.hodgson
Had a little time to look at my lisp and the attached works pretty well, a few tweeks to go but I am all good now. You may have the text rotated weirdly but it works fine for our 0 degrees orientation of North.
Richie
devitg
Message 8 of 10 (298 Views)
03-20-2013 05:59 PM in reply to: richie.hodgson
Ok
richie.hodgson
Message 9 of 10 (294 Views)
03-20-2013 08:02 PM in reply to: richie.hodgson
One quick question though, if the data was code,x,y,z instead of chainage,x,y,z what do I need to do to make that work? I get really confused with mixing up text and real numbers.
Richie
devitg
Message 10 of 10 (281 Views)
03-21-2013 04:50 AM in reply to: richie.hodgson
To fill the table , you need TEXT , so you shall use (RTOS number  2 4)   2 for decimal , 4 for precision or
From the VLIDE help
Converts a number into a string
(rtos number [mode [precision]])
The rtos function returns a string that is the representation of number according to the settings of mode, precision, and the system variables UNITMODE, DIMZIN, LUNITS, and LUPREC.
Arguments
number
A number.
mode
An integer specifying the linear units mode. The mode corresponds to the values allowed for the LUNITS AutoCAD system variable. The mode can be one of the following numbers:
1 Scientific
2 Decimal
3 Engineering (feet and decimal inches)
4 Architectural (feet and fractional inches)
5 Fractional
ITOA , integer to alfa
itoa
Returns the conversion of an integer into a string
(itoa int)
Arguments
int
An integer.
Return Values
A string derived from int.
Examples
Command: (itoa 33)
"33"
Command: (itoa -17)
"-17"
You are not logged in.
Announcements
Need installation help?
Ask the Community
