Visual LISP, AutoLISP and General Customization
what'S wrong with this lisp to import excel x y to cad
2 REPLIES 2
syria89
717 Views, 2 Replies
i attached a lsp with and excel
the lsp does creat circles with diameter of 5 related to imported points from excel
i realsed that it is able to get the first column but can get the coordinate from the second one
                (setq posX (atof (substr line 1 nPos)))  (this is ok)
                (setq posY (atof (substr line (1+ nPos)))) (not this one)
2 REPLIES 2
Kent1Cooper
in reply to: syria89
Given this line [the first one]:
288390.6;5052934
and that nPos has been set by this:
(setq nPos (vl-string-position (ascii ";") line))
then nPos will be 8, and posX will be 288390.6.  But you want posY to be read starting at the tenth position, not the ninth, because (substr) counts the first character as 1, whereas (vl-string-position counts it as 0.  Try:
                (setq posY (atof (substr line (+ nPos 2))))
Kent Cooper, AIA
syria89
in reply to: Kent1Cooper
A BIG THANKS
Robot Happy
”Boost
