Thanks, James. I'll take it this is the last entry (it's about time) in this
thread. Yes I had experimented with the CopyObjects method to clone LayerStates
to a different owner's dictionary; works well. Unfortunately, my head was
turned to saving the copy in the layout's ExtensionDictionary which (I think)
caused access problems during the LayoutSwitching. Regardless, the obstacle
still becomes one of not being able to ascertain a rename or a creation by copy,
but what the hey? You may be right that it can all work simply by handles.
Hmmm... wish I had more time to play. Got home at 11; gotta leave by 7. Sounds
like craps, eh? 🙂 Thanks for all the insight. G'night.
John Uhden, Cadlantic
http://www.cadlantic.com
Sea Girt, NJ
"James Buzbee" wrote in message
news:40449e8d$1_2@newsprd01...
> Then one last opinion(if I understand the underlying problem).
> Why not mirror layer state data in your own custom dictionary. Then you can
> easily "restore" a deleted layer state programatically, add a custom xrecord
> with handle information of the layout(s) the layer state is attached to, and
> keep track of associated layer states like deleting un-used ones (maybe
> providing the user with a back-up mechanism in that instance).
> You would still access the LayerStateManager via activex to apply layer
> states to the active document, you just have your own "untouchable" record
> to keep things coordinated. You could set up your own GUI for createing,
> editing, and associating layer states with layouts AND react to the layer
> command when users "inadvertainly" do an end around and edit layer states
> there.
> I've certainly got alot out of this discourse. I can see where a program
> like this would have far reaching benifits in a small architectural firm
> that doesn't need a heavy handed "Standards" program. I don't have time
> right now - I don't know how I'm going to get through this month - but I'd
> like to play around with this when I get a chance. I'll fill you in if I do
> jb
