I am having problem calling the ObjectARX functions from VLIDE editor. Everything works fine from AutoCAD command prompt. here is the ObjectARX code snippet.
Registring the function
int (*func)() = setVariable;
acedDefun(_T("setVariable"),1);
acedRegFunc(func,1);
SetVariable Function
int setVariable()
struct resbuf *rb = acutBuildList(5005,
_T("Unicode String"), 5000);
int resval = acedPutSym(_T("test"), rb);
acutRelRb(rb);
return 1;
If I call (setVariable) from AutoCAD command prompt its works fine, but while calling from VLIDE editor the AutoCAD becomes nonresponsive. I cannot do anything on AutoCAD but the VLIDE editor works fine. I cannot even close the VLIDE editor because the Exit menu option goes into disable mode.
the Same Arx woks fine in AutoCAD 2014 I am migrating ARX from 2014 to 2015 and I am stuck.
Please help me I have tried all possible options but not finding clue.
Thanks in advance.
@Anonymous wrote:
I am having problem calling the ObjectARX functions ...
Hi keyur4you,
should be easier to get help on ObjectARX functions in the ObjectARX forum
Henrique
