aqdam1978
Message 1 of 6 (447 Views)
vlax-dump-object problem
447 Views, 5 Replies
03-16-2013 09:13 AM
I prepared a code to dump properties of selected object to a text file:
(defun elist ( e / d)
	(cond
        (   (or(and(eq 'ENAME (type e)) (setq d (entget e)))
               (and (listp e) (setq d e) (setq e (cdr (assoc -1 d))))
            (princ "(\n" des)
            (foreach pair d
                (princ " " des)
				(prin1 pair des)
                (princ "\n" des)
            (princ ")\n\n\n" des)
			(princ "\n");;;in text screen (command prompt window)
			(vlax-dump-object (vlax-ename->vla-object e) T);; dump in text screen :(
			(princ "------------------------ Nested Object: ----------------------------\n" des)
            (if (= 1 (cdr (assoc 66 d)))
                (while
                    (progn
						(elist (setq e (entnext e)))
                        (not (eq "SEQEND" (cdr (assoc 0 (entget e)))))
    (princ)
(defun c:AA-EE ( / des)
	(setq des (open "elist.txt" "w" ))
	(repeat 10 (princ "\n"))
	(elist (car (entsel)))
	(close des)
	(textpage)
	(startapp "Notepad" "elist.txt")
usage:
load this file
type AA-EE in command window
(test it on 1 simple object and one complex object e.g. a title block)
 It works fine, but "vlax-dump-object" command just sent datas to text screen and I can't control it to send its datas to a text file.
does anybody has an idea?
Abbas
pbejse
Message 2 of 6 (415 Views)
Re: vlax-dump-object problem
03-16-2013 10:51 PM in reply to: aqdam1978
Abbas
(defun c:Demo ()
  (setvar 'Qaflags 2)
  (command "_Logfileon")
  (vlax-dump-object (vlax-ename->vla-object (car (entsel "\nSelect Object:"))) t)
  (command "_LogfileOff")
  (setvar 'Qaflags 0)
  (startapp "Notepad" (getvar "Logfilename"))
hmsilva
Message 3 of 6 (397 Views)
03-17-2013 07:45 AM in reply to: aqdam1978
Abbas,
as pbejse already shown, the only way I also know is through the "logfile", and as you wrote, "I can't control it to send its datas to a text file", here is an example on how you can do that, in this "test", the data from "vlax-dump-object" is stored in a variable named "dump", this way it is possible to send all the information to your text file.
(defun c:test (/ obj file fopen line logf rest str itm)
  (if (setq obj (vlax-ename->vla-object (car (entsel))))
    (progn
      (setvar "logfilemode" 1)
      (setq file  (getvar "logfilename")
	    dump  nil
	    logf nil
      );; setq
      (vlax-dump-object obj T)
      (princ)
      (setvar "logfilemode" 0)
      (if (setq fopen (open file "r"))
	(progn
	  (while (setq line (read-line fopen))
	    (if	(> (strlen line) 0)
	      (setq logf (cons line logf))
	    );; if
	  );; while
	  (close fopen)
	);; progn
      );; if
      (if (setq rest (member "; Property values:" logf))
	(setq num (+ (- (length logf) (length rest)) 2))
      );; if
      (setq itm 0)
      (while (< itm num)
	(setq str  (nth itm logf)
	      dump (cons str dump)
	      itm  (1+ itm)
	);; setq
      );; while
    );; progn
  );; if
  (princ)
);; test
hope that helps
Henrique
aqdam1978
Message 4 of 6 (393 Views)
03-17-2013 08:08 AM in reply to: pbejse
Hi Pbejse,
Thank you for your code.
You teach me new things in AutoCAD!
Thanks aqgain,
Abbas
LOGFILEMODE
LOGFILEPATH
LOGFILENAME
LOGFILEON
LOGFILEOFF
Qaflags:
1     : ^C in menu macro cancels grips (acts like keyboard <Esc>).
2     : no pause during text screen listings.
4     : no "alert" dialogs (text display instead).
128 : accepts "screen picks" (point lists) via (command) function.
512 : sets Bind type to insert in R14
aqdam1978
Message 5 of 6 (383 Views)
03-17-2013 09:45 AM in reply to: hmsilva
Hi Henrique,
Thanks for your code, I updated my code with your code! and it's all I wanted!
(defun LOG2lst (e / file fopen line logf rest str itm)
	dump nil
	logf nil
  ;; setq
  (vlax-dump-object e T)
  (princ)
    (progn
	;; if
      ;; while
      (close fopen)
    ;; progn
  ;; if
  ;; if
  (setq itm 0)
  (while (< itm num)
	  itm  (1+ itm)
    ;; setq
  ;; while
  (princ)
  DUMP
;; LOG2lst
(defun elist (e / d d1 i)
  (cond
    ((or (and (eq 'ENAME (type e)) (setq d (entget e)))
     (princ "(\n" des)
     (foreach pair d
       (princ " " des)
       (prin1 pair des)
       (princ "\n" des)
     (setq d1 (LOG2lst (vlax-ename->vla-object e)))
     (setq i 0)
     (repeat (length d1)
       (write-line (vl-string-translate ";" " " (nth i d1)) des)
       (setq i (1+ i))
     (princ
       "\n\n------------------------ Nested Object: ----------------------------\n\n"
       des
       (while
	 (progn
  (princ)
(defun c:AA-EE (/ des)
  (setq des (open "elist.txt" "w"))
  (close des)
  (textpage)
usage:
load this file
Thanks again,
Abbas
hmsilva
Message 6 of 6 (381 Views)
03-17-2013 09:48 AM in reply to: aqdam1978
You're welcome, Abbas
glad you got a solution
Henrique
You are not logged in.
Ask the Community
