Visual LISP, AutoLISP and General Customization
(vla-...) syntax?
4 REPLIES 4
473 Views, 4 Replies
(vla-...) syntax?
This has been brought up in a few different threads.  However, they were all about one specific command and I could not find or (more likely) did not understand how to find the syntax for (vla-...) commands.  What I'm looking for is a way to go from the vba reference material to a (vla..), but maybe that's not where I should be looking??
4 REPLIES 4
dbroad
Briefly
VBA syntax:  object.method(args..)
VLA syntax: (vla-method object args...)
VLAX syntax (vlax-invoke object 'method args...)
VBA syntax for setting a property(roughly): object.property = value
VLA syntax: (vla-put-property object value)
VLAX syntax: (vlax-put object 'property value)
VBA syntax for getting a property: variable = object.property
VLA syntax:  (vla-get-property object)
VLAX syntax: (vlax-get object 'property)
Architect, Registered NC, VA, SC, & GA.
in reply to: dbroad
Thanks a bunch!!!  I might have been able to figure it outeventually comparing the various (vla- commands here in the forums with the VBA documentation, but it probably would have taken forever!  Hopefully this will help others like me who am trying to learn the (vla- extensions.
Thanks again for such a clear answer!
dbroad
You're welcome.  Glad to help.  There are also a couple of other vlax syntaxes but the ones I listed are the ones I use most often.  Others include vlax-get-property, vlax-put-property, and vlax-invoke-method. I don't use those as much because they require the values (most of the time) to be variants with points being safe-arrays.
in reply to: dbroad
"Safearrays and object types"  That's a whole nuther can of worms I don't feel like dealing with right now.  Smiley Wink
I have done a little VBA for Excel so I understand the object type thing but safearrays are ... like that airplane joke.
”Boost
