I am writting an AutoLISP program to plot layout using the page setup currently assigned to it ( plotter DWG to PDF). The reason is because my network connection is very slow and it takes me a lot of time to go through all those dialog boxes if I use the command PLOT. The only thing I want to change is the folder where I'd like to save the PDF file.
The following line is for the plotting
(vla-PlotToDevice (vla-get-Plot aDoc))
Now the PDF is saved in the same folder as the DWG file. How can I change the path where to save the PDF file?
Thanks a lot!
Xiangyu
