This is what i have.
(defun c:WB40 ()
(c:bv (setq vehname (WB40)
Vehunit (I)
startdrawpoint
(getpoint
"/nWhere would you like to Start the vehicle: "
vehbodylength
(180)
vehwidth (48)
vehfronthang
(48)
vehwheelbase
(150)
vehsteerlock
(6)
vehsteerlocktime
(28.4)
vehwheelwidth
(96)
vehrearhitch
(0.001)
trailhave (yes)
vehartangle
(75)
Trailname (WB-40-Trailer)
trailunits
(I)
trailerhitchtowheel
(330)
trailerwheelwidth
(102)
trailerfronthang
(36)
trailerbodylength
(360)
trailerwidth
(102)
(princ)
Here is the main code that i would like to use on my code to create the vehicle.
;;; BuildVehicle.LSP
;;; Copyright 2006 Stephen Hitchcox
;;; BuildVehicle.LSP draws vehicles for use by Tturn.lsp in AutoCAD.
;;; This program is free software under the terms of the
;;; GNU (GNU--acronym for Gnu's Not Unix--sounds like canoe)
;;; General Public License as published by the Free Software Foundation,
;;; version 2 of the License.
;;; You can redistribute this software for any fee or no fee and/or
;;; modify it in any way, but it and ANY MODIFICATIONS OR DERIVATIONS
;;; continue to be governed by the license, which protects the perpetual
;;; availability of the software for free distribution and modification.
;;; You CAN'T put this code into any proprietary package. Read the license.
;;; If you improve this software, please make a revision submittal to the
;;; copyright owner at hdesign@ica.net
;;; This program is distributed in the hope that it will be useful,
;;; but WITHOUT ANY WARRANTY; without even the implied warranty of
;;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
;;; GNU General Public License on the World Wide Web for more details.
;;; OVERVIEW
;;; BuildVehicle.LSP draws attributed blocks of vehicles that are required
;;; by Tturn.lsp, for approximating the paths of trucks as they drive.
;;; GETTING STARTED
;;; Load and run BuildVehicle. It will ask you for all of the parameters
;;; for your vehicle, and draw a unique attributed block. You can build a library
;;; of vehicles for future use. BuildVehicle.lsp runs using "BV" or "BuildVehicle"
;;; from the command line. Axles should be the "centroid" of any group of multiple
;;; axles.
;;; Data for turning angles and time to turn is for future use, so enter
;;; dummy data if you do not know it.
;;; enter "N" for no trailer, but still give place holder data for the non-existent
;;; trailer. It will not be drawn.
;;; The parameters are used to build a scale block of the vehicle you are
;;; defining, which is made into a block.
;;; You can change the attributes in the block if you make a mistake, but the block
;;; itself does not change size (it is not parametric).
;;; If you make a new block with the same name as an existing one, it will overwrite
;;; the old one, or perhaps fail. If this happens, erase all errant blocks, and purge
;;; the old block from the drawing file.
;;; Draw the path for the vehicle as the route taken by the front left tire. A future
;;; version of this program might add path by centre or by right side of vehicle, to
;;; suit other driving standards.
;;; After running Turn, manually adjust the route to move the vehicle off of collisions
;;; and then run turn again to see if you now can drive the route.
;;; Remember, there is almost no error correction in this program. If you enter
;;; impossible geometry, the program will happily draw it. Please report issues and
;;; requested functionality to the author.
;;; REFERENCE
;;; Vehicle dimensions (ft) Min. Outside Min. Inside
;;; Vehicle Width WB1 WB2 Rad Rad. (check)
;;; P (passenger) 7 11 24.0 13.8
;;; SU (single truck) 8.5 20 42.0 27.8
;;; BUS 8.5 25 42.0 24.4
;;; WB-40 8.5 13 27 40.0 18.9
;;; WB-50 8.5 20 30 45.0 19.2
;;; Development Notes:
;;; 1) implement better error correction
;;; 2) collect and share correctly dimensioned standard vehicles
;;; 3) revise to not require data for non-existent trailers, and to allow multiple
;;; trailers
;;; 4) revise to draw tires centred on the tire paths
;;; 5) 080205 imperial scaling issue resolved, and input for dimensional information
;;; revised to allow picks from drawing
;;;C:BV short form call for (C:BUILDVEHICLE)
(DEFUN
C:BV
(C:BUILDVEHICLE)
(DEFUN
C:BUILDVEHICLE
;;; NEED TO ADD SETTING OF DEFAULT VALUES HERE,
;;; THEN LOOP THROUGH TO CHANGE TO CUSTOM NUMBERS,
;;; THEN PRESENT USER WITH COMPLETE LAYOUT BEFORE CREATING BLOCK,
;;; AND ALLOW USER TO CHANGE BY GOING THROUGH LOOP AGAIN
(SETQ VEHNAME (GETSTRING T "\nEnter Name of Vehicle: "))
(SETQ INPUTTEST "f")
(WHILE (= INPUTTEST "f")
(PROGN
(SETQ
VEHUNITS
(GETSTRING "\nEnter Units Type 'M'etric or 'I'mperial: ")
(SETQ VEHUNITS (STRCASE VEHUNITS))
(IF (OR (= VEHUNITS "M") (= VEHUNITS "I"))
(SETQ INPUTTEST "T")
(PRINC
"\nSorry, this value cannot be used, please try again"
(SETQ
STARTDRAWPOINT
(GETPOINT "\nPick midpoint of front bumper: ")
(SETQ
VEHBODYLENGTH
(GETDIST STARTDRAWPOINT "\nLength of Vehicle: ")
(SETQ
VEHWIDTH
(* 2 (GETDIST STARTDRAWPOINT "\nHalf width of Vehicle: "))
;; Record VEHWIDTH
;; MAKEATTRIBUTE usage: (MakeAttribute InsPoint InsAngle Tag Value AttribLayer AttPrompt TextSize)
(MAKEATTRIBUTE
(POLAR STARTDRAWPOINT PI (/ VEHWIDTH 15))
90.0
"VEHWIDTH"
(RTOS VEHWIDTH 2)
"AttributeLayer"
"Vehicle width"
(/ VEHWIDTH 15)
(SETQ VEHBLOCKLIST (SSADD (ENTLAST)))
;; Record VEHBODYLENGTH
(MAKEATTRIBUTE
(POLAR
(POLAR STARTDRAWPOINT (* 1.5 PI) (* VEHWIDTH 0.55))
0.0
(/ VEHBODYLENGTH 2)
0.0
"VEHBODYLENGTH"
(RTOS VEHBODYLENGTH 2)
"AttributeLayer"
"Vehicle body length"
(/ VEHWIDTH 15)
(SSADD (ENTLAST) VEHBLOCKLIST)
;; Draw BODY
(DRAWBOX
(POLAR STARTDRAWPOINT (* 1.5 PI) (/ VEHWIDTH 2))
VEHBODYLENGTH
VEHWIDTH
"truckbody"
(SETQ
VEHFRONTHANG
(GETREAL "\nEnter front overhang from Bumper to Axle: ")
;; Record front axle offset
(MAKEATTRIBUTE
(POLAR STARTDRAWPOINT 0.0 (/ VEHFRONTHANG 2))
0.0
"VEHFRONTHANG"
(RTOS VEHFRONTHANG 2)
"AttributeLayer"
"Vehicle front overhang"
(/ VEHWIDTH 15)
(SETQ
VEHWHEELBASE
(GETDIST "\nEnter vehicle wheelbase: ")
(IF (< VEHBODYLENGTH (+ VEHFRONTHANG VEHWHEELBASE))
(PRINC
"\nCaution, Vehicle Length is shorter than sum of Front Overhang and Wheelbase. Errors could occur."
;; Record rear axle location
(MAKEATTRIBUTE
(POLAR STARTDRAWPOINT 0.0 (+ VEHFRONTHANG VEHWHEELBASE))
90
"VEHWHEELBASE"
(RTOS VEHWHEELBASE 2)
"AttributeLayer"
"Vehicle wheelbase"
(/ VEHWIDTH 15)
;; Record name of vehicle
(MAKEATTRIBUTE
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG (/ VEHWHEELBASE 2))
0.0
"VEHNAME"
VEHNAME
"AttributeLayer"
"Vehicle name"
(/ VEHWIDTH 10)
;; Record units of vehicle
(MAKEATTRIBUTE
(POLAR
(POLAR STARTDRAWPOINT (* 1.5 PI) (* VEHWIDTH 0.25))
0.0
(/ VEHBODYLENGTH 2)
0.0
"VEHUNITS"
VEHUNITS
"AttributeLayer"
"Vehicle units (Metric or Imperial)"
(/ VEHWIDTH 15)
;;; VehSteerLock isn't currently functional.
;;; (setq VehSteerLock 0.0)
(SETQ VEHSTEERLOCK (GETANGLE "\nEnter vehicle Steering Lock Angle: (note that this is required but not used at this time)"))
;; Record vehicle Steering Lock Angle
(MAKEATTRIBUTE
(POLAR STARTDRAWPOINT 0.0 (/ VEHFRONTHANG 3))
90.0
"VEHSTEERLOCK"
(ANGTOS VEHSTEERLOCK 0)
"AttributeLayer"
"Vehhicle steering lock angle"
(/ VEHWIDTH 15)
;;; VEHSTEERLOCKTIME isn't currently functional.
;;; (setq VehSteerLockTime 0.0)
(SETQ
VEHSTEERLOCKTIME
(GETREAL "\nEnter vehicle steering lock time: (note that this is required but not used at this time)")
;; Record vehicle steer lock time
(MAKEATTRIBUTE
(POLAR STARTDRAWPOINT 0.0 (* 2 (/ VEHFRONTHANG 3)))
90.0
"VEHSTEERLOCKTIME"
(RTOS VEHSTEERLOCKTIME)
"AttributeLayer"
"Vehicle steer lock time"
(/ VEHWIDTH 15)
(SETQ
VEHWHEELWIDTH
(GETDIST
"\nEnter maximum axle width to middle of wheels: "
;; Record wheel width
(MAKEATTRIBUTE
(POLAR STARTDRAWPOINT 0.0 VEHFRONTHANG)
90.0
"VEHWHEELWIDTH"
(RTOS VEHWHEELWIDTH 2)
"AttributeLayer"
"Vehicle wheel width"
(/ VEHWIDTH 15)
;; Draw tires
;; Define Tire Size as 1/10th of vehicle dimensions (arbitrary, could be a future setting)
(SETQ WHEELWIDTH (/ VEHWIDTH 10))
(SETQ WHEELLENGTH (/ VEHBODYLENGTH 10))
;; DRAW FRONT LEFT wheel
(SETQ
WHEELFLSTARTX
(+ (CAR STARTDRAWPOINT)
(- VEHFRONTHANG (/ WHEELLENGTH 2))
(SETQ WHEELFLSTARTY (- (CADR STARTDRAWPOINT) (+ (/ VEHWHEELWIDTH 2) (/ WHEELWIDTH 2))))
(DRAWBOX
(LIST WHEELFLSTARTX WHEELFLSTARTY)
WHEELLENGTH
WHEELWIDTH
"truckbody"
;; Draw front left target point
(SETQ
TARGETX
VEHFRONTHANG
(SETQ
TARGETY
(/ VEHWHEELWIDTH 2)
(DRAWTARGET
(LIST TARGETX TARGETY)
WHEELLENGTH
WHEELWIDTH
"truckbody"
;; Draw front right wheel
(SETQ
WHEELFRSTARTX
(SETQ
WHEELFRSTARTY
(+ (CADR STARTDRAWPOINT)
(- (/ VEHWHEELWIDTH 2) (/ WHEELWIDTH 2))
(DRAWBOX
(LIST WHEELFRSTARTX WHEELFRSTARTY)
WHEELLENGTH
WHEELWIDTH
"truckbody"
;; Draw rear left wheel
(SETQ
WHEELRLSTARTX
VEHWHEELBASE
(SETQ WHEELRLSTARTY (- (CADR STARTDRAWPOINT) (+ (/ VEHWHEELWIDTH 2) (/ WHEELWIDTH 2))))
(DRAWBOX
(LIST WHEELRLSTARTX WHEELRLSTARTY)
WHEELLENGTH
WHEELWIDTH
"truckbody"
;; Draw rear right wheel
(SETQ
WHEELRRSTARTX
VEHWHEELBASE
(SETQ
WHEELRRSTARTY
(DRAWBOX
(LIST WHEELRRSTARTX WHEELRRSTARTY)
WHEELLENGTH
WHEELWIDTH
"truckbody"
(SETQ
VEHREARHITCH
(GETDIST
"\nEnter distance from rear axle to hitch (forward is NEGATIVE): "
;;Draw hitch
(SETQ
CIRCLELIST
(LIST
(CONS 0 "CIRCLE")
;(CONS 100 "AcDbEntity")
(CONS 8 "truckbody")
;(CONS 100 "AcDbCircle")
(CONS 40 (/ VEHWIDTH 10))
(CONS
10
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG VEHWHEELBASE VEHREARHITCH)
(ENTMAKE CIRCLELIST)
(MAKEATTRIBUTE
(POLAR
STARTDRAWPOINT
0.0
90.0
"VEHREARHITCH"
(RTOS VEHREARHITCH 2)
"AttributeLayer"
"Vehicle rear hitch location (forward is NEGATIVE): "
(/ VEHWIDTH 15)
;; End of main vehicle entry
;; Start trailer entry
(INITGET 1 "Yes No")
(SETQ
TRAILHAVE
(GETKWORD
"\nDoes unit have a trailer? Yes/No: "
(MAKEATTRIBUTE
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG VEHWHEELBASE (* VEHREARHITCH 0.5))
90.0
"TRAILHAVE"
TRAILHAVE
"AttributeLayer"
"Does unit have a trailer"
(/ VEHWIDTH 15)
(COND
((= TRAILHAVE "Yes")
;; Vehicle articulation angle not functional
;; (setq VehArtAngle 20.0)
(SETQ VEHARTANGLE
(GETANGLE "\nEnter vehicle articulation angle: (note that this is required but not used at this time)")
(MAKEATTRIBUTE
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG VEHWHEELBASE (* VEHREARHITCH 1.5))
90.0
"VEHARTANGLE"
(ANGTOS VEHARTANGLE 0)
"AttributeLayer"
"Vehicle articulation angle"
(/ VEHWIDTH 15)
(SETQ TRAILNAME (GETSTRING "\nEnter name of trailer: "))
(PROGN
(SETQ
TRAILUNITS
(SETQ TRAILUNITS (STRCASE TRAILUNITS))
(IF (OR (= TRAILUNITS "M") (= TRAILUNITS "I"))
(PRINC
"\nSorry, this value cannot be used, please try again."
(SETQ
TRAILERHITCHTOWHEEL
(GETDIST
"\nEnter Distance from Hitch to Trailer Wheel: "
(SETQ
TRAILERWHEELWIDTH
(GETDIST "\nEnter maximum trailer axle width to middle of wheels: ")
(SETQ
TRAILERFRONTHANG
(GETDIST
"\nEnter Distance from Hitch to Front of Trailer: "
(SETQ
TRAILERBODYLENGTH
(GETDIST "\nEnter Overall Trailer Length: ")
(SETQ TRAILERWIDTH (GETDIST "\nEnter Trailer Width: "))
;; Record trailer Length
(MAKEATTRIBUTE
(POLAR
(POLAR STARTDRAWPOINT (* 1.5 PI) (* TRAILERWIDTH 0.55))
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
(/ TRAILERBODYLENGTH 2)
0.0
"TRAILERBODYLENGTH"
(RTOS TRAILERBODYLENGTH 2)
"AttributeLayer"
"Trailer body length"
(/ VEHWIDTH 15)
;; Record trailer name
(MAKEATTRIBUTE
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
0.0
"TRAILNAME"
TRAILNAME
"AttributeLayer"
"Trailer name"
(/ VEHWIDTH 10)
;; Record trailer units
(MAKEATTRIBUTE
(POLAR
(POLAR STARTDRAWPOINT (* 1.5 PI) (* TRAILERWIDTH 0.25))
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
0.0
"TRAILUNITS"
TRAILUNITS
"AttributeLayer"
"Trailer units"
(/ VEHWIDTH 15)
;; Record trailerfronthang
(MAKEATTRIBUTE
(POLAR
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
(- VEHREARHITCH (/ TRAILERFRONTHANG 2))
0.0
"TRAILERFRONTHANG"
(RTOS TRAILERFRONTHANG 2)
"AttributeLayer"
"Trailer front overhang"
(/ VEHWIDTH 15)
;; Record trailer to wheel length
(MAKEATTRIBUTE
(POLAR
(POLAR STARTDRAWPOINT (* 0.5 PI) (* TRAILERWIDTH 0.55))
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
0.0
"TRAILERHITCHTOWHEEL"
(RTOS TRAILERHITCHTOWHEEL 2)
"AttributeLayer"
"Trailer hitch to wheel length"
(/ VEHWIDTH 15)
;; Record trailer width
(MAKEATTRIBUTE
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
(- TRAILERBODYLENGTH TRAILERFRONTHANG)
90.0
"TRAILERWIDTH"
(RTOS TRAILERWIDTH 2)
"AttributeLayer"
"Trailer width"
(/ VEHWIDTH 15)
;; Record trailer wheel width
(MAKEATTRIBUTE
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
TRAILERHITCHTOWHEEL
90.0
"TRAILERWHEELWIDTH"
(RTOS TRAILERWHEELWIDTH 2)
"AttributeLayer"
"Trailer axle width to middle of wheels"
(/ VEHWIDTH 15)
;; Draw trailer
(DRAWBOX
(POLAR
(POLAR
STARTDRAWPOINT
0.0
(+ VEHFRONTHANG
VEHWHEELBASE
(- VEHREARHITCH TRAILERFRONTHANG)
(* 1.5 PI)
(/ TRAILERWIDTH 2)
TRAILERBODYLENGTH
TRAILERWIDTH
"trailerbody"
;; Draw rear left trailer tire
(SETQ
WHEELRLSTARTX
(- (+ (CAR STARTDRAWPOINT)
VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
TRAILERHITCHTOWHEEL
(/ WHEELLENGTH 2)
(SETQ WHEELRLSTARTY
(- (CADR STARTDRAWPOINT) (+ (/ TRAILERWHEELWIDTH 2) (/ WHEELWIDTH 2)))
(DRAWBOX
WHEELLENGTH
WHEELWIDTH
"trailerbody"
;; Draw rear right trailer tire
(SETQ
WHEELRRSTARTX
VEHFRONTHANG
VEHWHEELBASE
VEHREARHITCH
TRAILERHITCHTOWHEEL
(/ WHEELLENGTH 2)
(SETQ
WHEELRRSTARTY
(- (/ TRAILERWHEELWIDTH 2) (/ WHEELWIDTH 2))
(DRAWBOX
WHEELLENGTH
WHEELWIDTH
"trailerbody"
;;; ADD REQUEST HERE TO VERIFY DIMENSIONS AND LAYOUT,
;;; DUMP OUT LIST OF VALUES, AND ALSO ZOOM TO HIGHLIGHT VEHICLE
;;(makeblock VehBlockList StartDrawPoint (strcat "VEHICLELIB" VEHNAME))
;;makes a block without accessible attributes, needs fix
(COMMAND
"-block"
(STRCAT "VEHICLELIB" VEHNAME)
STARTDRAWPOINT
VEHBLOCKLIST
(COMMAND
"-insert"
STARTDRAWPOINT
(prompt(princ "\nDefinitions complete. Move vehicle into initial position and run TURN to track path. Position Front Left Tire on start of path, and rotate vehicle to approximate starting direction"))
(PRINC)
;;; End Buildvehicle |
;;;Start buildvehicle subfunctions
(DEFUN
DRAWTARGET
(STARTPOINT XLENGTH YLENGTH TARGETLAYER /)
(SETQ TARGETPOLYLIST NIL)
(SETQ
TARGETPOLYLIST
(LIST
(CONS 43 0.0)
(CONS 70 1)
;; closed pline if set
(CONS 90 4)
;; polyline length
(CONS 100 "AcDbPolyline")
(CONS 8 TARGETLAYER)
;; layer name
(CONS 0 "LWPOLYLINE")
(SETQ
TARGETPOLYLIST
(CONS
(CONS
10
(POLAR STARTPOINT (* PI 0.25) (/ YLENGTH 4))
TARGETPOLYLIST
(SETQ
TARGETPOLYLIST
(CONS
(CONS
10
(POLAR STARTPOINT (* PI 1.75) (/ YLENGTH 4))
TARGETPOLYLIST
(SETQ
TARGETPOLYLIST
(CONS
(CONS
10
(POLAR STARTPOINT (* PI 0.75) (/ YLENGTH 4))
TARGETPOLYLIST
(SETQ
TARGETPOLYLIST
(CONS
(CONS
10
(POLAR STARTPOINT (* PI 1.25) (/ YLENGTH 4))
TARGETPOLYLIST
(SETQ TARGETPOLYLIST (REVERSE TARGETPOLYLIST))
(ENTMAKE TARGETPOLYLIST)
(DEFUN
DRAWBOX
(STARTPOINT XLENGTH YLENGTH BOXLAYER /)
(SETQ BOXPOLYLIST NIL)
(SETQ
BOXPOLYLIST
(LIST
(CONS 43 0.0)
(CONS 70 1)
(CONS 90 4)
;; polyline length
(CONS 8 BOXLAYER)
;; layer name
(SETQ
BOXPOLYLIST
(CONS
(CONS
10
STARTPOINT
BOXPOLYLIST
(SETQ
BOXPOLYLIST
(CONS
(CONS
10
(POLAR STARTPOINT 0.0 XLENGTH)
BOXPOLYLIST
(SETQ
BOXPOLYLIST
(CONS
(CONS
10
(POLAR (POLAR STARTPOINT 0.0 XLENGTH) (/ PI 2) YLENGTH)
BOXPOLYLIST
(SETQ
BOXPOLYLIST
(CONS
(CONS
10
(POLAR STARTPOINT (/ PI 2) YLENGTH)
BOXPOLYLIST
(SETQ BOXPOLYLIST (REVERSE BOXPOLYLIST))
(princ "making boxpolylist")
(ENTMAKE BOXPOLYLIST)
(princ entlast)
(DEFUN
MAKEATTRIBUTE
(INSPOINT INSANGLE TAG VALUE ATTRIBLAYER ATTPROMPT TEXTSIZE)
(SETQ ATTRIBUTELIST NIL)
(SETQ
ATTRIBUTELIST
(LIST
(CONS 0 "ATTDEF")
;(CONS 100 "AcDbText")
;(CONS 100 "AcDbAttributeDefinition")
(CONS 1 VALUE)
(CONS 2 TAG)
(CONS 3 ATTPROMPT)
(CONS 8 ATTRIBLAYER)
(CONS 10 INSPOINT) ; not applicable insert point
(CONS 11 INSPOINT) ; this is the real insert point
(CONS 40 TEXTSIZE)
(CONS 50 (* (/ INSANGLE 360) (* 2 PI)))
(CONS 70 😎
(CONS 72 4)
(ENTMAKE ATTRIBUTELIST)
