dose anybody know why my variable keeps on putting out the symbols "ÿþa" instead of the select ctb.
heres my code:
(setq f (open "C:\\ICT\\AutoCAD_Architecture_Suite_2012\\CUSTOM\\TREADSTONE\\PEN\\MYPLOTSTYLE.PEN" "r")) (setq MYPLOTSTYLE (read-line f)) (close f) (Command "-Plot" "Y" MYLAYOUT MYOUTPUTDEVICE MYPAPERSIZE "Millimeters" MYPAPERORIENTATION "No" "layout" "Fit" "0.00,0.00" "YES" MYPLOTSTYLE "No" "No" "Yes" "No" "No" "No" "yes")
Solved by The_Caddie. Go to Solution.
@The_Caddie wrote:dose anybody know why my variable keeps on putting out the symbols "ÿþa" instead of the select ctb.
heres my code:
(setq f (open "C:\\....\\MYPLOTSTYLE.PEN" "r")) (setq MYPLOTSTYLE (read-line f)) (close f) (Command "-Plot" ... "YES" MYPLOTSTYLE ...)
Maybe this is too obvious a question, but I guess I have to ask: Is the MYPLOTSTYLE.PEN file a plain text file, and is the .ctb file name the first line in it?
yes the infamous pen file your quite right Kent though I'll add the ctb file name is the only thing in the pen/ text file...
Im also thinking its the fact i have a period in my file name which is giving the variable a headache?
@The_Caddie wrote:yes the infamous pen file your quite right Kent though I'll add the ctb file name is the only thing in the pen/ text file...
It may be the only thing there, but if the file is something like a word processor document file, or a spreadsheet, or who knows what else, rather than a plain text file, there could easily be other coding elements in the file [font and size designators, etc.], preceding the content you actually see when you open the file.
If it does come from some other kind of program, you could try opening it in a plain-text editor like Notepad if you can, and saving it there, to eliminate any such elements -- it will probably warn you about losing encoding. But that assumes you don't also need the file in whatever its original form is, for some other purpose.
Or you could try a (while) loop, repeating (read-line) until what it returns is just a text string ending in ".ctb", assuming that it will do that eventually [it might not, depending on how lines in the file are broken down].
I doubt the period is the problem, if it's just the separator between the file name and the file type -- the (open) function deals with those all the time.
nope its just a text file with just an extention type change i made up the text inside is compiled by a vb.net program though as you can see the other variables are working okay and they use the exact same method i have hoever taken the time to delete the file and re-make the whole thing by hand ussing plain old notepad howver the resulat remained the same?
