Hi Mark!
Try this:
(entget (car (entsel)))
-> Select the door
Door Object Info:
((-1 . ) (0 . "AEC_DOOR") (330 . ) (5 . "102F") (100 . "AcDbEntity") (67 . 0) (410 . "Model")
(8 . "A-Door") (100 . "AecDbEntity") (102 . "{AEC_SUBOBJECT") (300 .
"AecImpDoor") (100 . "AecImpObj") (3 . "") (100 . "AecImpEnt") (171 . 0)
(100 .
"AecImpGeo") (10 14500.0 14900.0 0.0) (15 0.959366 -0.282166 0.0)
(16 0.282166 0.959366 0.0) (210 0.0 0.0 1.0) (360 . )
(100 . "AecImpOpeningBase") (40 . 1500.0) (41 . 2000.0) (42 . 700.0)
(100 . "AecImpOpenFiller") (43 . 0.0) (70 . 50) (71 . 0) (100 .
"AecImpDoor")
(345 . ) (102 . "AEC_SUBOBJECT}")
(102 . "{AEC_NULLOBJECT}") (100 . "AecDbGeo") (100 . "AecDbOpeningBase")
(100 . "AecDbOpenFiller") (100 . "AecDbDoor"))
Try this: (entget (cdr (assoc 345 (entget (car (entsel))))))
-> Select the door
Door Style Info:
((-1 . ) (0 . "AEC_DOOR_STYLE") (5 . "102D")
(102 . "{ACAD_REACTORS") (330 . ) (102 . "}")
(330 . ) (100 . "AecDbObject") (102 .
"{AEC_SUBOBJECT")
(300 . "AecImpDoorStyle") (100 . "AecImpObj") (3 . "") (100 .
"AecImpDictRecord")
(3 . "") (100 . "AecImpDoorStyle") (40 . 50.0) (41 . 50.0) (42 . 50.0) (43 .
120.0)
(44 . 50.0) (70 . 1) (71 . 0) (72 . 0) (102 . "AEC_SUBOBJECT}")
(102 . "{AEC_NULLOBJECT}") (100 . "AecDbDictRecord") (100 .
"AecDbDoorStyle"))
Try this: (entget (cdr (assoc 330 (entget (cdr (assoc 345 (entget (car
(entsel)))))))))
-> Select the door
Door Styles Dictionnary Info:
((-1 . ) (0 . "DICTIONARY") (5 . "738")
(330 . ) (100 . "AcDbDictionary") (280 . 0) (281 . 1)
(3 . "Bifold - Double") (350 . ) (3 . "Bifold -
Single")
(350 . ) (3 . "Cased Opening")
(350 . ) (3 . "Hinged - Double")
(350 . ) (3 . "Hinged - Double - Exterior")
(350 . ) (3 . "Hinged - Double - Full Lite")
(350 . ) (3 . "Hinged - Single") (350 . )
(3 . "Hinged - Single - Exterior") (350 . )
(3 . "Hinged - Single - Full Lite") (350 . )
(3 . "Overhead - Sectional - 2100") (350 . )
(3 . "Pocket - Single") (350 . )
(3 . "Revolving - Simple") (350 . )
(3 . "Sliding - Double - Full Lite") (350 . )
(3 . "Standard") (350 . ))
The Plan:
1. (dictsearch (namedobjdict) "AEC_DOOR_STYLES")) to get [Door Styles List]
2. make the cycle to get DXF 350 from the next dotted pair after
(3 . "Desired_Door_Style_Name") to get []
3. make new selection set with (ssget "X" (list (cons 345
4. Oops! The Plan doesn't work!
And who can tell me WHY ???
(defun SearchForDoorStyle ( doorStyleName
DoorStyles firstStyle StylesList
nextName nextEntity doorStyleEntity
(setq DoorStyles (dictsearch (namedobjdict) "AEC_DOOR_STYLES"))
(setq firstStyle (assoc 3 DoorStyles))
(setq StylesList (member firstStyle DoorStyles))
(while (setq nextName (cdr (car StylesList)))
(setq StylesList (cdr StylesList))
(setq nextEntity (cdr (car StylesList)))
(if (= nextName doorStyleName)
(setq doorStyleEntity nextEntity)
) ; - 'if'
) ; - 'while'
doorStyleEntity
) ; - 'defun'
(defun SelectDoorsByStyle ( doorStyle / ss )
(setq ss (ssget "X" (list (cons 345 doorStyle))))
(princ)
) ; - 'defun SelectDoorsByStyle'
(defun sdoors ()
(SelectDoorsByStyle (SearchForDoorStyle "Overheads - Sectional - 2100"))
(princ)
Alexander V. Koshman
