vrod2000
Message 21 of 31 (815 Views)
Re: using Lisp to add a hyperlink to a specific attribute
03-17-2011 06:43 AM in reply to: pbejse
Sweet!
I'll try it out soon and let you know how it goes!
Right now, I'm thinking of starting my weekend early, so it might not be until Monday that I check it out.
thanks for the code, I'm sure I will get it to work.
vrod2000
Message 22 of 31 (799 Views)
03-21-2011 05:42 AM in reply to: pbejse
I tried it out this morning....the program works using my drawing list, however it is not deleting the existing hyperlinks.
Have you tested that part out?  As an example, make a small drawing list with values, then change it and rerun the program.
Message 23 of 31 (796 Views)
03-21-2011 06:05 AM in reply to: vrod2000
Of course I did,       :smileyhappy:
granting the attribute  a "clean" one or just one count of hyperlink  , tell you what
(defun c:givemethecount nil
(vl-load-com)
(print
(vla-get-count
(vla-get-hyperlinks
	(vlax-ename->vla-object (car (nentsel))))))
  (princ)
 Hit the attribute with this one and tell me what it says
or better yet.. post the drawing in here
Message 24 of 31 (790 Views)
03-21-2011 06:40 AM in reply to: pbejse
oops. :smileysurprised:
my bad
I think i know what happen.
Change this
  (strcat (cadr hpt) (car hpt) "*.dwg)
to
  (strcat (cadr hpt) (car hpt) ".dwg")
with the code before when you pick the attribute with givethepath thingy. i would show you a string with filename *.dwg
If by somehow you get a value more that 1 with givemethecount, i think i have an idea how to fix that
vrod2000
Message 25 of 31 (783 Views)
03-21-2011 07:34 AM in reply to: vrod2000
It is still not replacing the existing hyperlinks. This means if a drawing reference changes, it will still point to the prior hyperlink.    hmmmm.....
vrod2000
Message 26 of 31 (779 Views)
03-21-2011 07:51 AM in reply to: vrod2000
I ran that program.  The count is 5.  There must be some links ontop each other.
It can erase all hyperlinks for the matching attribute. That would be fine with me.
Also, if the attribute has no value, the hyperlink should be erased. (that way if a reference is removed, the hyperlink will go away).
attached is the sample drawing.
Message 27 of 31 (760 Views)
03-21-2011 08:32 PM in reply to: vrod2000
Got the file, tested it a dozen times for you
(defun c:HyperL  (/ blks dwglist str nw_lst blk hpt htp)
  (vl-load-com)
  (if (setq blks (ssget '((0 . "INSERT") (66 . 1))))
    (progn
      (setq DWGLST (open "c:/scripts/drawings/dwglst.txt" "r"))
      (while (setq str (read-line DWGLST))
        (if (not (eq str "EOF"))
          (setq nw_lst (cons (list (strcase str) (read-line DWGLST)) nw_lst))))
      (close Dwglst)
      (while (setq blk (ssname blks (setq cntr (1+ cntr))))
        (foreach
           at_str  (vlax-invoke
                     (vlax-ename->vla-object blk)
                     'GetAttributes)
          (if
            (setq hpt (assoc (strcase (vla-get-textstring at_str)) nw_lst))
             (progn
               (if (> (vla-get-count
                        (setq htp (vla-get-hyperlinks at_str)))
                      0)
                 (vlax-for cn htp
                 (vla-delete cn))) ;if Hyperlink Exist
               (vla-add
                 "File Hyperlink")))    ;if
          );foreach
        );while
      );progn
    );if ssget
  (princ))
I think  now its all good :smileyhappy:
vrod2000
Message 28 of 31 (749 Views)
03-22-2011 08:02 AM in reply to: vrod2000
:smileyvery-happy:
That did it!!!!   I just need to modify it, so it will simply make a selection set of all symbols on the drawing (no picking required).
This is something I'll work on in the next week. It is the least I can do.
Very nice so far!
New Member
dharandesign
Message 29 of 31 (703 Views)
How to add filepath in the cad drawing attribute using lisp
04-21-2011 02:51 AM in reply to: vrod2000
How to add filepath in the cad drawing attribute using lisp ?
Can anyone help me in this?
Message 30 of 31 (685 Views)
Re: How to add filepath in the cad drawing attribute using lisp
04-25-2011 05:34 AM in reply to: dharandesign
You mean the path of the current drawing?
(defun c:AddPrefix  (/ String)
  (vl-load-com)
  (cond (
    (and
     (setq sTring (car (nentsel "\nSelect Attribute:")))
     (eq (cdr (assoc 0 (entget String))) "ATTRIB")
     (vla-put-textstring
       (vlax-ename->vla-object String)
       (strcat
         (getvar 'Dwgprefix)
         (vla-get-textstring (vlax-ename->vla-object String)))))
 Hope this helps
 You need to invoke regen
You are not logged in.
Ask the Community
