Visual LISP, AutoLISP and General Customization
using Autocad Electrical API in a script
2 REPLIES 2
gcsjlewis
542 Views, 2 Replies
Could someone help me out with the following.....I am writing to a script file like so:
(setq scrfile "T:\\Acad_Autolisps\\Scripts\\New_Project_Scripts\\ai_insert.scr")
(setq scr (open scrfile "w"))
(write-line (strcat "_open\n\"" ai_dwgname "\"") scr)
The next line i am having issues with.  I need to write the following line exactly as is to the script file.  I have tried a couple of different ways but it will execute the command instead of writing to the script file.  If i copy and paste the following directly into the script, and run the script, it works fine.
 (c:wd_inplc_nd (list 26.5 20.5 0.0) "8" "00.00.00" nil nil 1 18 1 "V" (c:wd_find_sel_plc "1756-if16") nil)
How would i do this?
Thanks...
2 REPLIES 2
hmsilva
in reply to: gcsjlewis
Try
(write-line (strcat "(c:wd_inplc_nd (list 26.5 20.5 0.0) \"8\" \"00.00.00\" nil nil 1 18 1 \"V\" (c:wd_find_sel_plc \"1756-if16\") nil)") scr)
HTH
Henrique
gcsjlewis
in reply to: hmsilva
Perfect! !
________________________________
The information contained in this message is intended only for the personal and confidential use of the recipient(s) named above. If the reader of this message is not the intended recipient or an agent responsible for delivering it to the intended recipient, you are hereby notified that you have received this document in error and that any review, dissemination, distribution, or copying of this message is strictly prohibited. If you have received this communication in error, please notify us immediately, and delete the original message.
”Boost
