am in search of clues for this odd issue .
Ever since a few months , for no apparent reason autocad started this odd behavior :
- tool palette and design center stay locked no matter the lockui value - they unlock only when pressing CTRL.
- Under options / user preference tab , right click is set to "time related". It works as it should with
mouse button, but it wont work from windows shorctut key next to ALT GR on keyboard , which now repeats the last command regardless of setttings
also
- this problems occurs on my windows user account, on my pc . the other accounts on same pc , or my account on other pcs, work fine .
our IT even made new account for me, with same login name: problem persists.
any idea why ? thanks
Solved by owenwengerd. Go to Solution.
Do you have any third party applications (like QuikPik, for example) installed?
@Anonymous wrote:
unloading Quikpik did it . its back to normal .
But now you're missing out on all the features of QuikPik....
