Visual LISP, AutoLISP and General Customization
unlocking dxf codes
9 REPLIES 9
Message 1 of 10
gcsjlewis
605 Views, 9 Replies
unlocking dxf codes
I am trying to change a viewport scale through the dxf code:  I see that certain parts cannot be changed but I don't know if this is one of them.  Here's what I have so far:
(defun c:vps ()
(setq quickview (entget(car(entsel))))
 (setq g45 (cdr(assoc 45 quickview)))
(setq g41  (cdr(assoc 41 quickview)))
 (setq new1 (* g45 1.5))
(entmod (subst (cons 41 new1) (assoc 41 quickview) quickview))
The scale is a ratio between m-space height & p-space height.  So if I want all viewports to be 1:1.5 scale this is what I need to do, but my entmod command isn't working is there another way?
9 REPLIES 9
Message 2 of 10
Kent1Cooper
in reply to: gcsjlewis
@gcsjlewis wrote:
I am trying to change a viewport scale through the dxf code:  I see that certain parts cannot be changed but I don't know if this is one of them. ....
Neither the Height nor CustomScale VLA Properties show as Read-Only, so they should be changeable, but Is the Viewport locked?  If so, try first removing the 16384 bit from the (assoc 90) value in the entity data, or changing the DisplayLocked VLA Property from -1 to 0, then substitute the (assoc 41) value or assign a CustomScale VLA Property of [I'd have to think about whether 2/3 or 3/2, but you can find out easily enough by trying them both].  And presumably you'd want to then re-lock the Viewport by reversing what you did to unlock it.
Kent Cooper, AIA
Message 3 of 10
gcsjlewis
in reply to: Kent1Cooper
Viewport is unlocked. I have "(90 . 33344)". What does this actually do?
________________________________
The information contained in this message is intended only for the personal and confidential use of the recipient(s) named above. If the reader of this message is not the intended recipient or an agent responsible for delivering it to the intended recipient, you are hereby notified that you have received this document in error and that any review, dissemination, distribution, or copying of this message is strictly prohibited. If you have received this communication in error, please notify us immediately, and delete the original message.
Message 4 of 10
Kent1Cooper
The red ones below add up to 33344, so they would be the status characteristics of the Viewport.
90 Viewport status bit-coded flags:
1 (0x1) = Enables perspective mode
2 (0x2) = Enables front clipping
4 (0x4) = Enables back clipping
8 (0x8) = Enables UCS follow
16 (0x10) = Enables front clip not at eye
32 (0x20) = Enables UCS icon visibility
64 (0x40) = Enables UCS icon at origin
128 (0x80) = Enables fast zoom
256 (0x100) = Enables snap mode
512 (0x200) = Enables grid mode
1024 (0x400) = Enables isometric snap style
2048 (0x800) = Enables hide plot mode
4096 (0x1000) = kIsoPairTop. If set and kIsoPairRight is not set, then
isopair top is enabled. If both kIsoPairTop and kIsoPairRight are set,
then isopair left is enabled
8192 (0x2000) = kIsoPairRight. If set and kIsoPairTop is not set, then
isopair right is enabled
16384 (0x4000) = Enables viewport zoom locking
32768 (0x8000) = Currently always enabled
65536 (0x10000) = Enables non-rectangular clipping
131072 (0x20000) = Turns the viewport off
I don't have any other bright ideas about why you can't change it as you want, but if I think of anything, I'll write back.
Kent Cooper, AIA
Message 5 of 10
gcsjlewis
Thanks. Yeah just doing research I saw that "entmod" cannot be used with viewport dxf codes
Message 6 of 10
Kent1Cooper
This seems to work, even if the Viewport is locked:
(setq vpobj (vlax-ename->vla-object (car (entsel "\nSelect Viewport: "))))
(vla-put-CustomScale vpobj (/ 2.0 3))
.... or maybe you need it to be:
(vla-put-CustomScale vpobj (/ 3.0 2))
Kent Cooper, AIA
Message 7 of 10
BlackBox_
Just be mindful that the ActiveViewport Property Object must be 'put' back to the Document Object before changes made to same are visible.
"How we think determines what we do, and what we do determines what we get."
Message 8 of 10
Kent1Cooper
in reply to: BlackBox_
Not for me.  I just tried it again, in two different drawings, and changes were visible immediately.  [ADT2004 if it makes any difference.]
Kent Cooper, AIA
Message 9 of 10
BlackBox_
Change the Target.
Message 10 of 10
BlackBox_
@BlackBoxCAD wrote:
Change the Target.
FWIW - Here's a recent example of the Target issue requiring to be 'put' back.
”Boost
