I have been playing with attributes, I have one routine that will put attributes back at original location using ATTSYNC and another that will adjust height and width of those attributes.
Next hurdle is the position of the attributes in relation to the block. For example, I will have 2 blocks whose attributes are right on top of each other, so I can't read the attribute value. I want to pick one of the blocks, move the attribute and have that same movement applied to every instance of that block in the drawing.
Jason
