• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    try protect lisp
    325 Views, 9 Replies
    03-06-2008 02:39 AM
    Hello all,
    i try to protect lisp not be copy by people again and again.
    so i try to search different variable in each computer.
    what i try to do is , make lisp to check local variable in each computer.
    e.g.
    use (getvar "_LINFO") to find hardware lock number
    use _PKSER to find autocad serial number
    use (getvar "Loginname") to find window Login name
    but when users use copy version ....then it doesn't workT_T
    Can you guys help me a fever.
    is there any method in lisp or vlisp can help me find each compurters:
    1. Mac address.
    2. ip address.
    3. computer Identification code in portable license utility.
    or any other useful variable.
    Thank You So Much!!!!!!
    Please use plain text.
    Distinguished Contributor
    Re: try protect lisp
    03-06-2008 04:49 AM in reply to: fateyo
    This has been discussed many times. If you want to restrict a lisp to your company's office environment, then you need to check variables which relate to the office, not to the individual PC. Such as (getenv "userdomain"). Or you could use username or -pkser and compare it to a list of those that are allowed access.
    Most casual thieves only try to copy one lisp. If you make sure that your files are mutually interdependent, they probably won't figure out which files are necessary to make that one file work. For instance, have a startup file which checks "something" and sets a global variable, and don't let any lisp run unless that variable is set.
    None of this will work unless the lisp to be "protected" is compiled/encrypted. Use your imagination.
    03-06-2008 05:06 AM in reply to: fateyo
    Thank you Tom,
    i try to sell my lisp to china. As i know too many people using copy version of autocad and window, and somtimes they use ghost copy many many computer with same setting like: userdomain, username, autocad serial number, hardware lock number...of course included my lisp.......what i try to do is keep my lisp only can run on 1 computer. I make new lisp for every new computer by different variable like Mac address T_T.
    Thank you for your Help. what you suggest is cool and work in normal company/world.
    *Bill DeShawn
    03-06-2008 06:37 AM in reply to: fateyo
    How about having the lisp check the LOGINNAME system variable, so that it
    only works for one person with that Window Login?
    _________________________
    Bill DeShawn
    bdeshawn@nospamsterling.net
    http://my.sterling.net/~bdeshawn
    wrote in message news:5868129@discussion.autodesk.com...
    Thank you Tom,
    company/world.
    03-06-2008 06:41 AM in reply to: fateyo
    Something else you could do is compile it into a FAS file and require the user to enter a serial number on the first run that it stores into the registry. And maybe have that serial number be related to some variable on the computer that the user can't change.
    i.e. ABC-123-(last 4 of mac)-(logon name) or something.
    Or, it wouldn't be too hard to compile a lisp per each person who buys it and just get the info and compile it to only work on their comp.
    03-06-2008 07:31 AM in reply to: fateyo
    Thank You docsaintly,
    can registry copy from 1 computer to another?
    Or if they copy the whole harddisk by ghost to another one, will it work?
    because in china they all using copy software.
    to install new computer....ghost is good and fast.
    they normally do that. TT
    03-06-2008 07:42 AM in reply to: fateyo
    Thank You Bill,
    As i know some of them......all computer using same login name (adminsitrator).
    because there are no AD "active directory" in their server.
    or all computer not login by domain when working. they only working by workgroup.
    they just save user and password when click on the server location.
    03-06-2008 07:54 AM in reply to: fateyo
    docsaintly,
    Can you tell me how to make first run then keep it stores into the registry please? I having compile lisp into a FAS before.
    is it one of the function of FAS ? or i need to do it in lisp?
    03-07-2008 01:16 AM in reply to: fateyo
    Thank you for everybody's help!!!!!!
    i got the solution.
    i download doslib from www.mcneel.com
    it has a function like
    Command: (dos_serialno "d:") drive d: serial no.
    "FC35E197"
    Command: (dos_macaddress)
    ("00:15:58:4C:B7:2C")
    by compile a lisp to vls per each computer.
    before my lisp run, it check local computer's mac address or harddisk drive serial no.
    then we can protect our lisp for 1 compuuter only.
    Thanks again. Message was edited by: fateyo
    New Member
    02-02-2013 09:31 PM in reply to: fateyo
    Hi I just want to ask how did u do it compiling the those doslib in your lisp to protect it.  Can you give me an idea or sample of vlx as I want to protect my lisp too.
    Hope to hear from you.
    Thanks!
    ram
