Hi!
I 've found a lisp it turns 2 layers: layer1 and layer2 (with toggle) on or off.
Now I want instead off layers on-off it must toggle thaw-freeze.
I thought "on"must be "thaw" and "off" must be "freeze".
But that does'nt work.
can you help me?
gr. László
on and off:->
(defun c:layertoggle ()
(if (setq flag (tblsearch "LAYER" "Layer1" ""))
(command "-layer" (if (minusp (cdr (assoc 62 flag))) "on" "off") "Layer1" ""))
(if (setq flag (tblsearch "LAYER" "Layer2" ""))
(command "-layer" (if (minusp (cdr (assoc 62 flag))) "on" "off") "Layer2" ""))
(princ)
@Anonymous wrote:Hi!
Yes, you can change "on" to "thaw" and "off" to "freeze", but you also need to change what it tests for. When a Layer is off, its color number [the 62 code entry] is negative. When it's frozen, it's the 70 code entry that holds that information -- it contains a 1 bit. It won't necessarily be just 1, because the 70 code also includes a 4 bit if the Layer is locked, and may cover some other conditions, too. So you need to check for the 1 bit regardless of whatever other bits may be included. The way to do that is with (logand):
(command "-layer" (if (= (logand (cdr (assoc 70 flag)) 1) 1) "thaw" "freeze") "Layer[X]" ""))
But there's another way to do this, that doesn't even need to bother checking whether the Layer is frozen or not -- it will freeze it if it's thawed and thaw it if it's frozen, with the same operation, using not (if) but the mysterious yet very powerful (boole) function:
(setq
laydata (entget (tblobjname "layer" "YourLayerName"))
laydata
(subst
(cons 70 (boole 6 (cdr (assoc 70 laydata)) 1))
(assoc 70 laydata)
laydata
); end subst
); end setq
(entmod laydata)
Autocad says: ; error: malformed list on input.
where does it go wrong?
My code:
(defun c:layertogle ()
((setq Laydata (entget (tblobjname "layer" "Layer1"))
laydata
(subst
(assoc 70 laydata)
laydata
); end subst
); end setq
(entmod laydata)
(princ)
Another question:
Is there a reference manual where I can find codes like: 62 en 70?
@Anonymous wrote:Autocad says: ; error: malformed list on input.
My code:
((setq Laydata (entget (tblobjname "layer" "Layer1"))....
Another question:
There's an extra left parenthesis before the setq function name. Change ((setq... to (setq....
Search the Discussion Group for things like DXF Reference, or association list codes, to find a lot of leads to sources of information about what the different entries mean.
Now its'working thank you!
laydata
(subst
(assoc 70 laydata)
laydata
); end subst
); end setq
(entmod laydata)
(princ)
And for both layers?
For Layer2. Can I type: (setq Laydata (entget (tblobjname "layer" "Layer1" "layer2")) or something??
@Anonymous wrote:Now its'working thank you!
No -- you don't want to set two Layers' worth of information into one variable, even if (tblobjname) would accept two Layer names [which it won't], because the remainder of the routine will only "find" the first 70-code entry, and (entmod) couldn't change both Layers from one list, anyway.
Personally, I would do two Layers by having a generic sub-routine [and that layertogle name is already appropriately generic], and then calling it up for both Layers via a command that uses that sub-routine for each Layer name, this way [untested]:
(defun layertoggle (layname / laydata); <-- note no C:, and a pre-slash argument
(setq
laydata (entget (tblobjname "layer" layname))
laydata
(subst
(assoc 70 laydata)
laydata
); end subst & 2nd laydata
); end setq
(entmod laydata)
); end defun - layertoggle
(defun C:LayerToggle-1-2 ()
(layertoggle "Layer1"); feeds Layer name as argument to sub-routine, to be used where layname occurs
(layertoggle "Layer2")
); end defun
Thank you,
But it doesnt work when I typ in the autocad prompt the command:
layertoggle or layertoggle1-2.
I'm trying to learn autolisp and visualisp. What is the fasted way to learn it?
gr. László
