hi ,
i like to work with block system in my project , but i dont like to use block editor or refedit for every action inside my block ...i found some lisps for add or remove objects from blocks but not enough for dont use to block editors , i need to lisp for use ordinary command for blocks without get them inside if ther is possibility ...
would be nice to share with us if somebody has the similar lisp
Do any of the system variables listed >here< help? Not exactly what you want, I know, but it should get you closer.
(if ("mysolution"=answer) then (click "Accept As Solution"))
