Show only
Search instead for
I am looking for someting to convert text to mtext.
I am aware to the TXT2MTXT but this does not work like i need it to.
The command above will allow a selection of mutiple text but then it converts all that text to one piece of mtext.
I am looking for something that will allow me to select mutiple text objects and it convert them to mtext without combining them into one piece of text.
reason for this
We have some contour lables that are all justified left and once selected to change the size
of the text it does not line up with the line any longer
So if i can get them to be mtext i can change the justification all at once then asign a new text height and then the text will line up right.
{code}
;changes text to individual mtext by Carl B.
(princ "\nType T2M to start")
(defun c:t2m ()
(setq Tset (ssget '((0 . "*TEXT"))))
(setq Setlen (sslength Tset)
Count 0
(repeat SetLen
(setq Ename (ssname Tset Count))
(command "_txt2mtxt" Ename "")
(setq Count (+ 1 Count))
(princ)
{code}
BTW... if you use Express tools' Tjust command you can change the text's justification, but the position will stay the same
Check your spelling. You loaded the old one. The names are slightly different. Keep in mind if you have already converted the individual text elements to MTEXT elements. You will have to explode them to start over.
