Hi ,
i have a text or attribute text wich is showing me the code , for example : AC-G-01 , i know that if i seperate this words and numbers as attribute block text i can change number tags with plusser lisp which i already have , but this is not exactly what i want to do , because there are many codes in my project and it s sometime being as att.block(without words separate) and sometimes just a text ..
so what i want to do :
* i click one of those codes ,and lisp will use this choise as a referans text
* i wanna specify value like 2 , 3 , 5 or which number i want ( this value can be 1 if i didnt specify number )
* after that when i click to text or attribute text , lisp will assign new number to selected text..
example : my ref.text (or att text ) is AC-G-25
i specified value : 2
when i click to text or att text , new number will be AC-G-27 , next one AC-G-29 , next AC-G-31 , 33 , 35 ,37
* and it would be useful if lisp remember the last code name and ask me that i wanna use last name as a referans text or specify new one ..
i think it is going to be difficult to do in lisp , i m waiting your share if somobody think this before ..thank you
With attached routine ALTEXT.vlx,
you can complete the task with the following 2 steps:
1. Select text or attribute one by one in order
2. Use settings as below
You can also save above selected objects as a group for future quick selection and revision
