Hi, I was wondering if we can edit table using macros.
For example, I want to select a table for the title block using the command prompt or simple specifying the cell on a specific table and put some USER input. Because I want to automate table insertion information using macros (AR) or creating codes.
I am not sure exactly what you want to do.
The best I can figure from your description and what I know is that you want to edit the AutoCAD database itself? If so, here is a good introductory lesson on editting the AutoCAD database using LISP. If this doesn't answer your question, try to restate your question more clearly and give a specific example of what you want to do.
http://www.afralisp.net/autolisp/tutorials/into-the-database.php
Thank you for your quick response, to be more specific:
I want to know how I can edit a table using a macro. I have for example 90 drawings (.dwg) which all need the same input but macro command (copy / past) does not go from cell to cell or does not allow me to continue my playback macro.
Hope this helps, thanks
