i have one table make which field from block. Is possible sum?
Try this one from my oldies, badly designed though
(defun C:TBSUM(/ acsp adoc blk_obj col en header headers hgt i line row sset table tablelist tbl_data tmp) (vl-load-com) (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object))) ) (or acsp (setq acsp (vla-get-block (vla-get-activelayout adoc))) ) (setq hgt 0.12) (if (setq sset (ssget '((0 . "insert")(2 . "Superficie")))) (progn (while (setq en (ssname sset 0)) (setq blk_obj (vlax-ename->vla-object en)) (foreach att (vlax-invoke blk_obj 'getattributes) (setq tmp (cons (vla-get-textstring att) tmp))) (setq tbl_data (append tbl_data (list(reverse tmp)))) (setq tmp nil) (ssdel en sset)))) (setq tablelist (mapcar '(lambda (x) (list (car x)(atof (vl-string-subst "." "," (cadr x)))))tbl_data)) (setq tablelist (vl-sort tablelist '(lambda (a b)(< (car a)(car b))))) (setq table (vlax-invoke acsp 'addtable (getpoint "\nPick table location: ") (+ 3(length tablelist)) (length (car tablelist)) (* hgt 1.5) (* hgt 8) )) (vla-put-regeneratetablesuppressed table :vlax-true) (vla-setcelltextheight table 0 0 5) (vla-settext table 0 0 "TITLE") (vla-setcelltextheight table 0 0 (* hgt 2)) (setq headers (list "Name" "Sup.")) (setq col 0) (while (setq header (car headers)) (vla-setcelltextheight table 1 col (* hgt 1.25)) (vla-settext table 1 col header) (setq col ( 1+ col)) (setq headers (cdr headers)) ) (setq row 2) (while (setq line (car tablelist)) (setq col 0) (foreach item line (vla-setcelltextheight table row col (* hgt 1.25)) (vla-settext table row col item) (setq col (1+ col))) (setq row (1+ row)) (setq tablelist (cdr tablelist))) (vla-settext table row 0 "Total=") (vla-setcelltextheight table row 0 (* hgt 1.25)) (vla-settext table row 1 (strcat "=SUM(B2:B" (itoa (1- (vlax-get-property table 'rows)))")" )) (vla-setcelltextheight table row 1 (* hgt 1.25)) (setq i 0) (while (< i (vlax-get-property table 'rows)) (vla-setrowheight table i (* hgt 1.5))(setq i (1+ i))) (vla-put-VertCellMargin table (* hgt 0.1)) (vla-put-HorzCellMargin table (* hgt 0.1)) (vlax-put-property table 'height (* (vlax-get-property table 'rows)(* hgt 1.5))) (vlax-put-property table 'width (* (vlax-get-property table 'columns)(* hgt 8))) (vla-put-regeneratetablesuppressed table :vlax-false) (princ) )
yeah¡¡¡ work¡¡¡ I have throw something similar, badly designed too,I am a beginner
(vl-load-com) (defun C:tablasup ( / *MS* attValue attValue2 CNT I LST MYTABLE PT1 ROW SSET TLST) (setq altura_texto 5) (setq lst '() i 0 *ms* (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))) ) ; prompt the user to select closed polylines (princ "\n Seleciona bloques ") (if (setq sset (ssget '((0 . "INSERT")))) (progn (repeat (setq cnt (sslength sset)) (setq attValue (GetAttributeValue (ssname sset i) "DEPENDENCIA")) (setq attValue2 (GetAttributeValue (ssname sset i) "SUP_UTIL")) (setq tlst (list attValue attValue2)) (setq lst (cons tlst lst)) (setq i (1+ i)) ) (setq pt1 (getpoint "\nPunto inserción tabla: ")) ; add the new table (setq myTable (vla-AddTable *ms* (vlax-3d-point pt1) (+ 3 cnt) 3 ;numero de columnas 0.5 ; altura filas 4)) ; anchura columnas ; the next three lines set the header text (vla-setText mytable 0 0 "SUPERFICE UTIL") (vla-setText mytable 1 0 "Dependencia") (vla-setText mytable 1 1 "Sup.") (setq row 2) (setq colObj (vlax-create-object "AutoCAD.AcCmColor.19")) (vla-SetRGB colObj 98 136 213) (vla-SetBackgroundColor myTable (+ acHeaderRow acTitleRow) colObj) (vla-put-Vertcellmargin myTable 0.05) ;margen vertical de texto (vla-put-Horzcellmargin myTable 0.15) ;margen horizontal de texto (vla-setTextheight myTable acTitleRow 0.15) ;altura texto titulo (vla-setTextheight myTable acHeaderRow 0.1) ;altura texto cabecera (vla-setTextheight myTable acDataRow 0.11) ;altura texto celdas (vla-setAlignment myTable acTitleRow acMiddleCenter) (vla-setAlignment myTable acHeaderRow acMiddleCenter) (vla-setAlignment myTable acDataRow acMiddleright) (vla-SetRowHeight myTable 0 0.5) (vla-SetRowHeight myTable 1 0.5) (vla-SetColumnWidth myTable 0 1.5) (vla-SetColumnWidth myTable 1 1) (vla-SetColumnWidth myTable 2 0.5) (foreach item lst (vla-setText mytable row 0 (Car item) ) (vla-setText mytable row 1 (Cadr item) ) (vla-setText mytable row 2 (strcat "m²") ) (vla-SetRowHeight myTable row 0.5) ;altura de fila insertada (setq row (1+ row)) ) ; On the last row, total up the area (vla-setText mytable row 0 (strcat "Total=") ) (vla-setText mytable row 1 (strcat "%<\\AcExpr (Sum(B3:B" (itoa (+ 2 cnt)) ")) \\f \"%lu2%pr2%ps%zs8\">%") ) (vla-setText mytable row 2 (strcat "m²") ) (vla-SetRowHeight myTable row 0.5) ;altura de fila insertada (vlax-release-object myTable) (vlax-release-object *ms*) ); end progn ; if no closed polylines were selected, ; end the program with this message (princ "\nNo has seleccionado bloques. ") ); end if (princ) ); end defun ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; Get Attribute Value - Lee Mac ;; Returns the value held by the specified tag within the supplied block, if present. ;; Arguments: ;; blk - [ent] Block (Insert) Entity Name ;; tag - [str] Attribute TagString ;; Returns: [str] Attribute value, else nil if tag is not found. (defun GetAttributeValue (blk tag / val enx) (while (and (null val) (= "ATTRIB" (cdr (assoc 0 (setq enx (entget (setq blk (entnext blk)))))) ) ) (if (= (strcase tag) (strcase (cdr (assoc 2 enx)))) (setq val (cdr (assoc 1 enx))) ) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
To export to excell is better for me that "m²" will be another colunm.
but de field lost,and the alone table is not updated alone,but it does not matter because meke very faster wich this lips
The solution is a reactor right?
sorry for my english.
