Josh,
I might be wrong, but I don't think you can do it with a ssget filter alone.
You'll have to post-process the line selection set in some form. Either use the 10
and 11 codes and calculate the distance between those points. Or use vlisp to get the
line Length property. I think the latter method is easier, but both will work.
Joe Burke
"Jtgodwin" wrote in message
news:27085718.1077289123195.JavaMail.jive@jiveforum1.autodesk.com...
> Hi guys,
> I need some help, I want to use the ssget command to select a set of lines that are
less than .090" long. I can select all the lines but I don't know how to filter out
everything that is longer than .090" long.
> Here is what I have so far: (setq entx (ssget "X" '((0 . "LINE"))))
> I would appreciate any help.
> Thanks
> Josh
