Visual LISP, AutoLISP and General Customization
ssget & entdel
3 REPLIES 3
675 Views, 3 Replies
ssget & entdel
I want to delete an entity made through ssget. Unfortunately it won't work
if I use (entdel InnSet)
How can I delete this object? Thanks for any help (acad 2000)
(princ"\nSelect Openings (or for none)... " )
(if (setq InnSet (ssget '((0 .
CIRCLE,ELLIPSE,SPLINE,POLYLINE,LWPOLYLINE")))
(entdel InnSet) ;;;this line is near the end of my code
3 REPLIES 3
ENTDEL expects an ENAME as an argument, not a PICKSET. If it's your
intention to erase everything you selected, you can either feed the
selection set to the erase command or loop through the set, deleting
objects one at a time:
(setq i -1)
(repeat (sslength InnSet)
(entdel (ssname InnSet (setq i (1+ i))))
"That's no ordinary rabbit."
http://www.acadx.com
Visit my site for a chance to win
a free, autographed copy of
Jerry Winters' "AutoCAD Visual Basics"
"Kiwi Russ" wrote in message
news:A5E2D01616611B331CAA4225FEDCC5A9@in.WebX.maYIadrTaRb...
won't work
2000)
code
Hi Frank
thanks for the reply. However I'm not sure how to make it
work.
Why do you setq i to -1? and do I need to place this after ssget has been
selected ?
also (repeat(sslength InnSet) etc is this at the end of the code?
> (setq i -1)
Selection sets are 0 based, so the first item in the set has an "Index" of
zero, the second has an "Index" of 1 etc....
> do I need to place this after ssget has been selected ?
Yes.
(setq InnSet (ssget.......))
(setq i -1)
-Jason
news:60476D6EB8D19301FDC93E663EA95CA9@in.WebX.maYIadrTaRb...
> Hi Frank
> work.
> selected ?
> > (setq i -1)
”Boost
