Gee, give us a little time! {grin}. It's not necessary to re-post your
question so soon. I answered your first post. But I forgot to include:
In addition to any replies you might receive or already received, you may
find more information or responses by posting future connectivity related
questions in the following discussion group:
Web browser: http://discussion.autodesk.com/forum.jspa?forumID=16
Newsreader: news://discussion.autodesk.com/autodesk.autocad.connectivity
jrf
Autodesk Discussion Group Facilitator
Please do not email questions unless you wish to hire my services
On Wed, 8 Aug 2007 04:18:24 +0000, GemT wrote:
> I am trying to insert text into the summaryinfo (dwgprops) using the code
below. I would like the text to come from an SQL statement, is that
possible? Or do I have to create a variable using the SQL as it's value and
then insert the variable into the code below?
> (vl-load-com)
> (defun c:ADD_PROPS (/ doc db si author nc nc2 nc3 value3 value4)
> (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
> (setq db (vla-get-Database doc))
> (setq si (vla-get-SummaryInfo db))
> (vla-put-author si "John");;;;;;;;;;;;;;;;;;;;;;I would like "John" to
come from an SQL statement or variable
> (vla-put-comments si "New comments")
> (vla-put-hyperlinkbase si "http://AddURL")
> (vla-put-keywords si "New keywords")
> (vla-AddCustomInfo si "siPutKey" "siPutValue")
> (setq nc (vla-numcustominfo si))
> (vla-SetCustomByKey si "siPutKey" "siPutValueByKey")
> (vla-GetCustomByKey si "siPutKey" 'value3)
> (if (/= "siPutValueByKey" value3)
> (princ "*** Error SetCustomByKey\n")
> (vla-SetCustomByIndex si (1- nc) "siPutCustomByIndexKey"
> "siPutCustomByIndexValue")
> (vla-GetCustomByKey si "siPutCustomByIndexKey" 'value4)
> (if (/= "siPutCustomByIndexValue" value4)
> (princ "*** Error SetCustomByIndex\n")
> (vla-RemoveCustomByIndex si (1- nc))
> (setq nc2 (vla-numcustominfo si))
> (if (/= nc2 (1- nc))
> (princ "*** Error RemoveCustomByIndex")
> ; Remove property
> (vla-RemoveCustomByKey si "siPutKey")
> (setq nc3 (vla-numcustominfo si))
> (princ "*** Error RemoveCustomByKey")
> (vlax-release-object si)
> (vlax-release-object db)
> (vlax-release-object doc)
> (princ)
> (princ)
> Gemma
