Try this tip from www.dotsoft.com:
If you used special characters in TEXT objects, such as %%130 for the
centerline symbol, when using MTEXT this coding does not work.
There is a big difference in the behavior of special characters between TEXT
and MTEXT objects. In MTEXT objects you do don't
use %%###, instead ...
1) Press and hold the Alt key.
2) Type your 4-digit code on the number pad, like 0129.
3) Release your Alt key.
The character that shows in the editor doesn't reflect the actual character,
but then neither did %%129.
Dean Saadallah
www.pendean.com
"Ian Maclean" wrote in message
news:D8010C25B3EA1A533C6D9959FE0A1FA0@in.WebX.maYIadrTaRb...
> Here's the scoop:
> Client has added special characters to their Release 2.6 ROMANS.SHX file.
> Traditionally, they access the characters using their decimal code (%%131,
> %%132, etc.). This does not work in MTEXT, however.
> I have "converted" these special characters to the ROMANS Unicode font.
The
> %%131 method still works in DTEXT and TEXT, but does not work in MTEXT.
The
> only way to get the characters in MTEXT is, of course, to input their
> hexadecimal value (\U+0082, \U+0083, etc.).
> Question:
> What is the method or shape file syntax for defining special characters
> similar to AutoCAD's diameter and degree symbols, where a letter key code
is
> used (%%C or %%D, for example)? Can I assign my special characters to
other
> keys using the "%%" mechanism (%%X or %%Y for example)? I know I can
> replace a keyboard character with the special symbol, but that's not
> desirable.
> Thanks,
> Ian
