- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: setting DIMLFAC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Knooli,
I would encourage you to avoid techniques to manipulate dimlfac based on scale factors. Such techniques are simply not needed. (AutoCAD user for more than 25 years).
Best practice is to work on object full size and dimension them in the same space they are drawn in IMO. If I need to have multiple scales on a single sheet, I typically work with each scale in its own drawing file and xattach the separate files into a sheet file. Others would use several annotation scales within a single model space and use paper space for scaling the plots.
Another technique is to wrap the objects inside block and use bedit. Problem with that is that bedit always resets the drawing scale to 1:1 which is annoying.
Others use viewports for scaling and dimension in paper space of the sheet they are plotting.
I prefer not to work behind others who have scaled object in model space so that dimensions and the distance command can no longer measure them. To add information or to edit such a drawing requires checking the properties of the dimensions, finding dimlfac, scaling the objects back to full size, and then re-scaling them.
Good luck.
Re: setting DIMLFAC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for your reply
Kent& dbroad,
I don't understand how to use paper space. Normally, our full drawing have more then hundred objects, difference size of each object. If I set the viewing scale, all the pages size cannot make it standardize to keeping softcopy and hardcopy. Actually, I need to make like Inventor “Detail” command, can be scale up and scale down object, but dimension same as original object.
Pbejse,
Yes, I missed the data lisp.
The data lisp is use to call tooling_info.lsp, this lisp is using in other software and not is autolisp.
Attached dwg file included data information, when running tcmr.lsp will skip the data lisp.
Re: setting DIMLFAC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
knlooi wrote:Thanks for your reply
Pbejse,
**** Try the lisp routine now*****
I commented that part where i the modifed the code [see attached]
I totally agree with kent and dbroad regarding scaling the drawing and using paperpsapce though
But since you already had it setup the way you had might as well help you out a little.
Cheers
BTW:
Take out coment tag where you load the data.lsp, I left it there while testing your code
HTH
Re: setting DIMLFAC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
As i was watching the video you posted, you mentioned there that you want the DIMLFAC value to maintain the
value of 1
So
(progn (setvar 'Dimlfac (* 1.22222 scale1))
(command "_-dimstyle" "_apply" obj "")
(setvar 'Dimlfac 1);<----- here
or here
(setvar "osmode" oosm)
(setvar 'Dimlfac 1);<----- or here
) (alert "User Cancel!")
HTH
Re: setting DIMLFAC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Pbejse,
Thank you very much, the lisp work is very good now.
One more question need your help is the dimension missing dia. and tolerance, can use the lisp to set it back?
Re: setting DIMLFAC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
knlooi wrote:Pbejse,
Oh that... Sure it can be done
Questions:
What other dimension properties beside Tolerance do you usually override?
Theres a long list for such, so i need to reduce the number to a few selected properties
Answer those Q's then I'll iupdate the code and get back to you
Re: setting DIMLFAC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Easiest solution is to repalce all this
(setvar 'Dimlfac 1)
to this
(command "_dimoverride" "DIMLFAC" (* 1.22222 scale1) "" obj "")
Try it.
Re: setting DIMLFAC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Pbejse,
Thanks your help!
Is symmetrical and deviation.
Re: setting DIMLFAC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks your help!
Glad I could help.
There's still a lot of improvement that can be done on your lisp code. Did you wirte this one yourself?
Code after code you will understand and learn what works and what doesnt.
Keep on coding knlooi
Cheers ![]()
Re: setting DIMLFAC
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok, I try to write this lisp. Thanks again.
