Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
set basepoint during insertion of blocks with AutoLISP
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
185 Views, 3 Replies
01-14-2013 08:31 AM
hello to all
would like to set a base point during insertion of one block.
When not insert by AutoLISP, just type "b" to be able to change the base point.
But when I'm using an AutoLISP that inserts a block, it does not work, it interrupts the sequence of routine.
Anyone have a tip that can help me improve routine?
Lisp:
(defun c:carrobox() (setq #clayer (getvar "clayer")) (if (= unidades nil)(setq unidades "cm")) (if(= unidades "cm")(setq scalefactor 1.0)(setq scalefactor 0.01)) (if (= numberboxcar nil)(setq numberboxcar 1)) (if (= passoboxcar nil)(setq passoboxcar 1)) (setq frase (strcat "\nBloco de box [Inserir,Numero = " (itoa numberboxcar)",Soma = +"(itoa passoboxcar)",-----, Un = " unidades "]<Inserir>")) (initget "I N S U" 0) (setq op (getkword frase)) (cond ((= op "U")(if(= unidades "cm")(setq unidades "metros")(setq unidades "cm"))(C:carrobox)) ((= op "N")(setq numberboxcar(getint "\nNúmero do box atual: "))(C:carrobox)) ((= op "S")(setq passoboxcar(getint "\nIncremento a cada box: "))(C:carrobox)) ( (or(= op "I")(= op nil)) (inserirboxdecarro) ) ) (setvar "clayer" #clayer) ) (defun inserirboxdecarro() (if (not (tblsearch "layer" "box de estacionamentos"))(command "._-layer" "m" "box de estacionamentos" "c" "13" "" ""))(progn(command "._-layer" "on" "box de estacionamentos" "thaw" "box de estacionamentos""")(setvar "clayer" "box de estacionamentos")) (command "._INSERT" "box de carro.dwg" "scale" scalefactor PAUSE pause numberboxcar) (setq numberboxcar (+ numberboxcar passoboxcar)) (inserirboxdecarro) )
Thanks In Advance
Re: set basepoint during insertion of blocks with AutoLISP
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-17-2013 12:38 AM in reply to:
Gustavo_Bernardi
(defun inserirboxdecarro () (if (not (tblsearch "layer" "box de estacionamentos")) (command "._-layer" "m" "box de estacionamentos" "c" "13" "" "" ) ;_ end of command ) ;_ end of if (progn (command "._-layer" "on" "box de estacionamentos" "thaw" "box de estacionamentos" "" ) ;_ end of command (setvar "clayer" "box de estacionamentos") ) ;_ end of progn (command "._INSERT" "box de carro.dwg" "scale" scalefactor) (while (not (zerop (getvar 'cmdactive))) (command pause) ) ;_ end of while (vla-put-textstring (car (vlax-invoke (vlax-ename->vla-object (entlast)) 'GetAttributes ) ;_ end of vlax-invoke ) ;_ end of car numberboxcar ) ;_ end of vla-put-textstring ;_ end of command (setq numberboxcar (+ numberboxcar passoboxcar)) (inserirboxdecarro) )
HTH
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-23-2013 09:12 AM in reply to:
pbejse
That helped a lot. Just wanted to know what made it work.
is it?
TKS
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-25-2013 06:36 AM in reply to:
Gustavo_Bernardi
Gustavo_Bernardi wrote:That helped a lot. Just wanted to know what made it work.
is it?(while (not (zerop (getvar 'cmdactive))) (command pause)TKS
Yes Gustavo_Bernardi, it sets the command in "pause" mode indefinitely until user ends the "insert" command.
Then it assigns the string value to the attribute.
Cheers
