• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    set basepoint during insertion of blocks with AutoLISP
    174 Views, 3 Replies
    01-14-2013 08:31 AM
    hello to all
    would like to set a base point during insertion of one block.
    When not insert by AutoLISP, just type "b" to be able to change the base point.
    But when I'm using an AutoLISP that inserts a block, it does not work, it interrupts the sequence of routine.
    Anyone have a tip that can help me improve routine?
    Lisp:
    (defun c:carrobox()
    (setq #clayer (getvar "clayer"))
    (if (= unidades nil)(setq unidades "cm"))
    (if(= unidades "cm")(setq scalefactor 1.0)(setq scalefactor 0.01))
    (if (= numberboxcar nil)(setq numberboxcar 1))
    (if (= passoboxcar nil)(setq passoboxcar 1))
    (setq frase (strcat "\nBloco de box [Inserir,Numero = " (itoa numberboxcar)",Soma = +"(itoa passoboxcar)",-----, Un = " unidades "]<Inserir>"))
    (initget "I N S U" 0)
    (setq op (getkword  frase))
    (cond
    ((= op "U")(if(= unidades "cm")(setq unidades "metros")(setq unidades "cm"))(C:carrobox))
    ((= op "N")(setq numberboxcar(getint "\nNúmero do box atual: "))(C:carrobox))
    ((= op "S")(setq passoboxcar(getint "\nIncremento a cada box: "))(C:carrobox))
    (or(= op "I")(= op nil))
    (inserirboxdecarro)
    (setvar "clayer" #clayer)
    (defun inserirboxdecarro()
    (if (not (tblsearch "layer" "box de estacionamentos"))(command "._-layer" "m" "box de estacionamentos" "c" "13" "" ""))(progn(command "._-layer" "on" "box de estacionamentos" "thaw" "box de estacionamentos""")(setvar "clayer" "box de estacionamentos"))
    (command "._INSERT" "box de carro.dwg" "scale" scalefactor PAUSE pause numberboxcar)
    (setq numberboxcar (+ numberboxcar passoboxcar))
    (inserirboxdecarro)
    Thanks In Advance
    Please use plain text.
    Re: set basepoint during insertion of blocks with AutoLISP
    01-17-2013 12:38 AM in reply to: Gustavo_Bernardi
    (defun inserirboxdecarro ()
    		(command
    	"._-layer"
    	"m"
    	"c"
    	"13"
    	) ;_ end of command
    		) ;_ end of if
    			(progn (command
    	 "._-layer"
    	 "on"
    	 "thaw"
    	 ) ;_ end of command
    		 ) ;_ end of progn
    			(command "._INSERT" "box de carro.dwg" "scale" scalefactor)
    			(while (not (zerop (getvar 'cmdactive)))
    		(command pause)
    		) ;_ end of while
    			(vla-put-textstring
    		(car
    	(vlax-invoke
    (vlax-ename->vla-object (entlast))
    'GetAttributes
    ) ;_ end of vlax-invoke
    	) ;_ end of car
    		numberboxcar
    		) ;_ end of vla-put-textstring
     ;_ end of command
    			(inserirboxdecarro)
    HTH
    01-23-2013 09:12 AM in reply to: pbejse
    That helped a lot. Just wanted to know what made it work.
    is it?
    (command pause)
    TKS
    01-25-2013 06:36 AM in reply to: Gustavo_Bernardi
    is it?
    (command pause)
    TKS
    Yes Gustavo_Bernardi, it  sets the command in "pause" mode indefinitely until user ends the "insert" command.
    Then it assigns the string value  to the attribute.
    Cheers
