self intersection
06:15 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hy,
Does anybody know if is there a property or method, or any other way, to check if it is possible to extrude one polyline or not? My intention was to write a routine wich could filter 2d polyline with a "self-intersection" ..
Tanks, Jacopo Russo.
The following code is the only way I have found, but it is not very smart..
;;; this function checks if any selected object has self-intersections
;;; trying to extract regions from the entities *JAC 2002*
(defun C:SELFCHK ()
(prompt "AutoInt Fuction Running *JAC 2002*")
(command "_LAYER" "_NEW" "_autoint_chk_temp"
"_MAKE" "_autoint_chk_temp"
(command "_REGION" (setq selection (ssget)) "")
(setq selection
(ssget "p" '((-4 . "")))
;; select any object in previous selection sect, wich is not a region
(command "_UNDO" "2")
;; undo creating new layer and extracting regions
(if (not (= selection nil))
;; if any self intersection exists ...
(progn ;; execute the following instructions:
;; loops trough the self-intersecting objects found and paint them with cyan "ink"
(setq N1 0
SSL (sslength selection)
(while (< N1 SSL)
(setq object (entget (ssname selection N1)))
(paintobj object)
(setq N1 (1+ N1))
;; while
(prompt "\ntest copmplete")
(prompt "\n")
(prompt (itoa SSL))
(prompt " Auto intersections found in selected objects.")
;; progn
;; if
(if (= selection nil)
;; if no self intersection exists ...
(prompt
"\nNo Auto Intersection was found in selected objects."
(princ)
(defun paintobj (object / ink)
;; cambia colore a un oggetto
(setq ink 4)
(setq b3 (append object (list (cons 62 ink))))
(entmod b3)
(defun C:SELFCHK ()
(setq selection
(setq N1 0
(while (< N1 SSL)
(paintobj object)
(setq N1 (1+ N1))
;; while
(prompt "\n")
(prompt (itoa SSL))
;; progn
;; if
(prompt
(princ)
(setq ink 4)
(entmod b3)
