Visual LISP, AutoLISP and General Customization
selecting only loaded xrefs
6 REPLIES 6
TherealJD
1553 Views, 6 Replies
i want to know what i need to modify to select only x-refs that are loaded. TIA 🙂
(>= (cdr (assoc 70 (tblsearch "BLOCK" (cdr (assoc 2 entl))))) 4)
6 REPLIES 6
scot-65
in reply to: TherealJD
Unfortunately I was never able to *grab* xrefs using tblsearch.
Even though the xref is a block, it is not recognized as an item
that can be searched using tblsearch.
Here is a snippet of code that will gather all xrefs.
   (while (setq d (tblnext "BLOCK" (not d)))
    (if (assoc 1 d)...
There is a VL* equivalent out there as well...
scot-65
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
pbejse
With code will give you a list of XREF and its status
(defun c:SelXref  (/ Xr_lst)
  (vlax-for
     blk  (vla-get-blocks
            (vla-get-activedocument (vlax-get-acad-object)))
    (if (eq (vla-get-isXref blk) :vlax-true)
      (setq Xr_lst
         (cons
           (cons
             (vla-get-name blk)
             (if (> (vla-get-count blk) 0)
               "Loaded" "Unloaded"))
           Xr_lst))))
  (foreach n Xr_lst (print n))
  (princ))
 USAGE:
command: SelXref
("XREFDrawing1" . "Loaded")
("XREFDrawing2" . "Unloaded")
I thik you already know what to do next
Smiley Happy
pbejse
in reply to: pbejse
You can do it this way if you need to have a selection set
(defun c:SelXref  (/ adoc blks objs vl_ob xr)(vl-load-com)
  (setq adoc (vla-get-activedocument (vlax-get-acad-object))
    	blks (vla-get-blocks adoc))
  (if (setq objs (ssget "_x" '((0 . "INSERT"))))
    (mapcar
      '(lambda (nm)
         (setq vl_ob (vlax-ename->vla-object nm))
                   (setq xr (vla-item blks
                          (vla-get-effectivename vl_ob))))
                 :vlax-false)
           (ssdel nm objs)
           (if (= (vla-get-count xr) 0)
             (ssdel nm objs))))
      (vl-remove-if 'listp (mapcar 'cadr (ssnamex objs)))))
  ;(....)<-- put your routine here  (sssetfirst nil objs)
  (princ)
Hope this helps
TherealJD
in reply to: pbejse
This looks promising. I'll try it out. Thanks! Smiley Happy
msarqui
in reply to: pbejse
Sorry but I don't get it.
What I need to do if, for exemple, I would like to detach all unreferenced PDF?
Thanks!
Moshe-A
in reply to: msarqui
”Boost
