Visual LISP, AutoLISP and General Customization
Valued Contributor
Message 1 of 9 (392 Views)
Accepted Solution
selecting object and passing to vla-offset
392 Views, 8 Replies
02-29-2012 09:01 AM
Hi, I'm trying to complete the code to select a p-line on layer G-POLY-GSF w/o asking for input. this (setq ent (ssget "X" (list (cons 8 "G-POLY-GSF"))) dosen't seem to work. What I'm I missing here?
(defun c:smileysurprised:f8 (/ ent dist obj)
(vl-load-com)
(setq ent (car (entsel "\nSelect line to offset: "))
;(setq ent (ssget "X" (list (cons 8 "G-POLY-GSF")))
(setq dist 8)
;(initget (+ 1 2 4 64))
;(setq dist (getdist "\nEnter offset distance: "))
;(initget (+ 2 4) "Yes No")
(setq obj (vlax-ename->vla-object ent))
;(vla-offset obj dist)
(vla-offset obj (* dist -1));outside
Valued Mentor
Message 2 of 9 (386 Views)
Re: selecting object and passing to vla-offset
02-29-2012 09:19 AM in reply to: cummins600
 (setq ent (ssget "X" (list (cons 8 "G-POLY-GSF"))) creates a selection set.. (vlax-ename->vla-object needs an entity name.  You can convert the selection set to a list of entities or iterate through it using (ssname ent [number])
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Valued Contributor
Message 3 of 9 (369 Views)
02-29-2012 11:50 AM in reply to: Shneuph
I'm really getting trip'd up with this one. Would I be on the right track with this (setq obj (vlax-ename->vla-object (ssname ent)))?
(vl-load-com)
;(setq ent (car (entsel "\nSelect line to offset: "))
(setq dist 8)
;;; (setq obj (vlax-ename->vla-object ent))
*Expert Elite*
Hallex
Message 4 of 9 (367 Views)
02-29-2012 11:57 AM in reply to: cummins600
Take a look closely at this code
sorry didn't add some explanation, see Help
{code}
(defun C:test (/ adoc ans axss ffobj fobj offd sfobj sobj ss)
   (setq adoc
   (vla-get-activedocument
     (vlax-get-acad-object)
   (if (setq ss (ssget))
     (progn
       (not (vl-catch-all-error-p
       (vl-catch-all-apply 'vla-clear (list (vla-get-pickfirstselectionset adoc)))
       (sssetfirst ss ss)
       (setq axss (vla-get-pickfirstselectionset adoc))
       (setq offd (getdist "\nOffset distance :"))
       (initget "Yes No")
       (setq ans (getkword "\nBoth sides? [Yes/No] <Yes>:"))
       (vlax-for obj axss
  (cond ((eq "No" ans)
  (setq fobj  (vla-offset obj offd)
        ffobj (car (vlax-safearray->list
       (vlax-variant-value fobj)
  (vlax-put ffobj 'color 130)
        (T
  (vlax-put ffobj 'color 71)
  (setq sobj  (vla-offset obj (- offd))
        sfobj (car (vlax-safearray->list
       (vlax-variant-value sobj)
  (vlax-put sfobj 'color 32)
   (princ)
{code}
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Valued Contributor
Message 5 of 9 (363 Views)
02-29-2012 12:10 PM in reply to: Hallex
Seems like this shouldn't be too hard, but it's kicking me good. It's just not clicking for me.
Valued Mentor
Message 6 of 9 (354 Views)
02-29-2012 01:06 PM in reply to: cummins600
Yes, your'e on the right rack, but (ssname) requires 2 arguments...  The selection set and the index of the item
http://docs.autodesk.com/ACD/2011/ENU/filesALR/WS1a9193826455f5ff1a32d8d10ebc6b7ccc-6935.htm
Valued Contributor
Message 7 of 9 (347 Views)
02-29-2012 01:44 PM in reply to: Shneuph
Sweet, that got me over the hump. Thanks.
(vl-load-com)
(setq dist 8)
(setq obj (vlax-ename->vla-object (ssname ent 0)))
*Expert Elite*
Kent1Cooper
Message 8 of 9 (344 Views)
02-29-2012 01:52 PM in reply to: cummins600
As Schneuph posted:
If there's only going to be one thing in the selection set, you would use index number 0:
In addition to that, you could also simplify some things:
If the Layer is known, you can shorten the (ssget) filter list with a dotted-pair list:
  (setq ent (ssget "X" '((8 . "G-POLY-GSF"))))
[but maybe that will ultimately be a Layer name taken from a selected object or something, put into a variable, in which case you would need to keep the (list (cons... format].
And you can make a negative number more simply than by multiplying it by -1:
(vla-offset obj (- dist));outside
Kent Cooper
Valued Contributor
Message 9 of 9 (342 Views)
02-29-2012 01:57 PM in reply to: Kent1Cooper
Cool. In this case, there will be only one selection to select from so I think the 0 will work fine.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
