• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Visual LISP, AutoLISP and General Customization
    Distinguished Contributor
    select and bind all xrefs in modelspace
    296 Views, 10 Replies
    10-09-2012 07:25 AM
    Does anybody have any code that will select all xrefs in modelspace and bind (insert) them?
    the   -xref  bind command requires explicit names and if I use * it will also bind my titleblock xref in paperspace which I want to avoid.
    Striving to be a WOMBAT, Waste Of Money, Brains, & Talent...
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you!
    Please use plain text.
    *Expert Elite*
    Re: select and bind all xrefs in modelspace
    10-09-2012 07:52 AM in reply to: dtiemeyer
    (defun c:XrefBind (/ tmpObj)
      (vl-load-com)
      (vlax-for objs (vla-get-ModelSpace
    		   (vla-get-activedocument (vlax-get-acad-object))
        (if
          (and
    	(= (vla-get-ObjectName objs) "AcDbBlockReference")
    	(vlax-property-available-p objs 'Path)
    	(setq
    	  tmpObj (vla-Item
    		   (vla-get-Blocks
    		     (vla-get-ActiveDocument (vlax-get-Acad-Object))
    		   (vla-get-Name objs)
    	(not (assoc 71 (entget (tblobjname "block" (vla-get-Name objs)))))
           (vla-Bind tmpObj :vlax-true)
      (princ)
    HTH
    10-09-2012 10:28 AM in reply to: pbejse
    Works awesome, thanks. But how would I make it 'just run' without waiting for user input?
    *Expert Elite*
    Kent1Cooper
    10-09-2012 11:57 AM in reply to: dtiemeyer
    Here's another way to do it [minimally tested]:
    (foreach x
      (mapcar 'cadr (ssnamex (ssget "_X" '((0 . "INSERT") (410 . "MODEL")))))
      (setq blk (cdr (assoc 2 (entget x))))
      (if (assoc 1 (tblsearch "block" blk)) (command "_.xref" "_bind" blk))
    It finds all insertions in model space, puts them into a list of entity names, and for each one, looks at whether its entry in the Block table is an Xref by checking whether it has an "Xref path name" [the (assoc 1) entry -- regular Blocks don't have one].  If so, it binds that Xref name.
    If you want it to "just run" without User input, does that mean you want to do it in all drawings that you open?  Sounds dangerous, but if that's what you mean, you could include the above code in something automatic like acaddoc.lsp.  Otherwise, put it into a command name as with pbejse's routine.
    Kent Cooper
    10-09-2012 02:38 PM in reply to: Kent1Cooper
    Hi Kent,
    Thanks for that, it is exactly what I was looking for. And you're right, I did mean to 'invoke' it manually but then let the command complete without user input.
    Cheers!
    Dustin
    *Expert Elite*
    10-09-2012 06:14 PM in reply to: dtiemeyer
    Glad it helps
    Not sure what you meant by 'just run' though.  :smileyhappy:
    Member
    10-18-2012 10:58 PM in reply to: dtiemeyer
    can it be modified to detach unloaded Xrefs then bind all loaded xref?
    "memories fade but the scars still linger"
    *Expert Elite*
    10-19-2012 12:19 AM in reply to: NOD684
    Are you aware that ithe code process exclusively Model space instances of XREF? also it ignores "unreferenced" xref as it wont be included in the selection set.
    Can you give more info.
    Cheers
    Welcome to the Forum NOD684 :smileyhappy:
    Member
    10-19-2012 12:59 AM in reply to: pbejse
    Thanks for the Welcome pbejse :smileyhappy:
    Yes am aware of that...i even tested it.
    i have a lisp before that detaches unloaded xref then binds all the loaded xref
    but unfortunately its not working in 2010 version...
    that is why i ask if it is possible to have such lisp
    Member
    10-19-2012 01:25 AM in reply to: dtiemeyer
    nevermind :smileyhappy: figured it out now :smileyhappy:
    its working fine...
