• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Valued Contributor
    bodhran
    Accepted Solution
    script to explode mtext
    397 Views, 6 Replies
    05-18-2011 02:49 PM
    Hi guys,
    I'm trying to explode mtext in a number of our dwgs, here's whaat i've come up with.
    EXPLODE
    (ssget "X" '((0 . "MTEXT")))
    it works fine if i run it at the command prompt but not if i run it via script?
    What am i not getting??
    B
    Please use plain text.
    *Pro
    scot-65
    Re: script to explode mtext
    05-18-2011 03:24 PM in reply to: bodhran
    A few of the LISP expressions are not allowed while inside a command.
    Try restructuring:
    (setq s (ssget...
    (command "EXPLODE" s "")
    (setq s nil)
    [untested]
    Valued Contributor
    bodhran
    05-18-2011 03:46 PM in reply to: scot-65
    Hi scot-65,
    well i've tried:
    (setq mt (ssget "X" '((0 . "MTEXT")))
    (command "EXPLODE" mt "")
    (setq mt nil)
    but it doeesn't work, i'm a novice at the ssget thing so it maybe something i'm just not getting right
    B
    Valued Mentor
    05-18-2011 04:29 PM in reply to: bodhran
    For some reason the explode command doesn't accept the entire selection set.  I tried your code and with the exception of a missing close parenthesis it seemed like it should have worked.  I fixed that but it only exploded 1 of the mtext objects in the sslist.  This code adds them to an entitylist and then explodes each one...
    (setq mt (ssget "X" '((0 . "MTEXT"))))
    (setq ctr 0)
    (while (setq cent (ssname mt ctr))
     (Setq objlist (append (list cent) objlist))
     (setq ctr (1+ ctr))
    );while
    (foreach mtextobj objlist
      (command ".explode" mtextobj)
    );foreach
    (setq mt nil
          ctr nil
          objlist nil)
    bodhran wrote:
    (setq mt (ssget "X" '((0 . "MTEXT"))) <-- Missing ) here.
    BTW.. you can see that your code works if you run this line (setq mt (ssget "x" '((0 . "MTEXT")))) and then run (sslength mt)  That should return the count of objects in your mt selection set.
    BTW #2.. If you also do (setq mt (ssget "x" '((0 . "MTEXT")))) and then (command "move" mt "")  see what happens...
    ---sig---------------------------------------
    '(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
    Valued Contributor
    bodhran
    05-18-2011 04:32 PM in reply to: Shneuph
    **** parenthesis!!
    Thanks that's exxcellent!! work a treat!!
    B
    *Expert Elite*
    Kent1Cooper
    05-19-2011 04:21 AM in reply to: Shneuph
    Shneuph wrote:
    For some reason the explode command doesn't accept the entire selection set.  ...it only exploded 1 of the mtext objects in the sslist.  ....
    This has come up several times before -- search the discussion group for Explode and the mysterious QAFLAGS System Variable.
    Kent Cooper
    New Member
    peszel
    05-26-2011 03:11 AM in reply to: bodhran
    Try this:
    (defun C:MTXEX ( / ss )
      (setvar "QAFLAGS" 1)
      (setq ss (ssget "x" (list (cons 0 "MTEXT"))))
        (if ss
          (command "._EXPLODE" ss "")
      (setvar "QAFLAGS" 0)
    (princ "\n** Type MTXEX to invoke **")
    (princ)
    peszel
