In article <403bbe35$1_2@newsprd01>, none@yahoo.com says...
> is there a way to check if a file is read-only or locked from autolisp?
If you are talking about the current DWG that's loaded, then check out
the WRITESTAT system variable.
If you are talking about any file on disk, looks like you've got enough
other replies to keep you busy so I won't bother to add my $0.02 there.
Darren J. Young
CAD/CAM Systems Developer
Cold Spring Granite Company
202 South Third Avenue
Cold Spring, Minnesota 56320
Email: dyoung@coldspringgranite.com
Phone: (320) 685-5045
Fax: (320) 685-5052
