Visual LISP, AutoLISP and General Customization
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: radio cluster to select next dialog box
- Highlight
- Email to a Friend
Ahh, I think the light is starting to come on ![]()
I do have another question though...
Is it possible to have a base list and pull pieces from it to create a popup list?
i.e. (setq list '("1" "2" "3" "4" "5"......"20"))
and then later
(start_list "lst1")
(cond
if a add "1" "2" "3"
if b add "5" "6" "9" "10" ?
can't figure out if there is a way to combine the mapcar and nth functions or if i need something else all together.
- Highlight
- Email to a Friend
aesh wrote:Ahh, I think the light is starting to come on
and then later
(start_list "lst1")
(cond
You would want to step-through the "master list" (using nth or FOREACH) to create sub-lists.
Use CONS to create the sub-lists. Study up on FOREACH and CONS.
The CONS does have a small drawback - the elements of the list are reversed.
I'm sure you do not want the popup to display this way?
First create the individual variable(s), then mapcar 'add_list the variable.
(setq a nil b nil) ;just to show you that a and b can be nil to start.
(foreach x list
(if [whatever] (cons x a))
(if [whatever] (cons x b))
);foreach
(reverse a)
(reverse b)
Hope this helps.
