• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Distinguished Mentor
    Moshe-A
    Accepted Solution
    problem in callback function
    142 Views, 5 Replies
    09-15-2012 03:17 PM
    Hi Guys,
    i have encounter a problem in callback function...i am using (client_data_file) to attach string (in a list)
    to be transfer to callback function. in the callback i set a local variable to get this string and autocad set it
    to nil but if i declare the variable as global it works (not sure if it is a steady problem)
    does any one seen this or am i  missing something?
    here is an example of my code:
    (setq some_string "abcde")
    (client_data_tile "accept" "(some_string)")
    (action_tile "accept" "(ctrl_accept $data)")
    (defun ctrl_accept (data / str)
     (setq str (eval (car (read data)))) ; this returns nil
     (done_dialog 1)
    ; but this one works
    (defun ctrl_accept (data)
     (setq str (eval (car (read data)))) ; this returns "abcde"
     (done_dialog 1)
    thanks in advance
    Moshe
    Please use plain text.
    *Pro
    scot-65
    Re: problem in callback function
    09-17-2012 03:24 PM in reply to: Moshe-A
    For your first defun you declare a local variable STR which does not leave the
    confides of the opening and closing parenthesis of the defun. In other words,
    it is a local variable that stays local. If you want it to leave this area, you show
    one of the many tricks that are available.
    I personally keep the done_dialog on the same line as "accept". It's easier for me to follow...
    Try this (untested)
    ..."(setq str (control_accept $data))(done_dialog 1)"
    *Expert Elite*
    09-17-2012 06:06 PM in reply to: scot-65
    I concur...
    Moshe-A
    09-18-2012 12:38 AM in reply to: scot-65
    Hi Scot,
    thank you very much for your help.
    i expand a little of what i'm doing:
    suppose in main function i have a registry key and a file name
    (that were build in main and ofcourse defined as locals) as the user picks th OK button
    i need them in the (ctrl_accept) callback function to write the file name to registry.
    all of that include some error cheaking could not be done from (action_tile) call
    i suppose you agree with me?!
    the problem arise in buttons i use and edit_box tiles.
    this code is a small example of my program
    (defun ctrl_accept (data / rkey filename)
     (setq rkey (eval (car (read data)))
     (setq filename (eval (cadr (read data))))
     (if (vl-registry-read rkey)
      (vl-registry-write rkey "datafilename" filename)
     (done_dialog 1)
    (defun c:main (/ rkey filename dcl_id what_next)
     (setq rkey (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key) "\\Applications")
           rkey (strcat rkey "\\AppName")
     (if (not (vl-registry-read rkey))
      (vl-registry-write rkey)
     (setq filename "appdata.txt")
     (setq dcl_id (ai_dcl "appdata")); load dcl file
     (setq what_next 3)
     (While (> what_next 1)
      (if (not (new_dialog "app_dialog" dcl_id "" '(-1 -1))); open dialog
       (exit)
      (client_data_tile "accept" "(rkey filename)")
      (SetQ what_next (start_dialog)); start dialog
     ); while
     (princ)
    as i said earlier the problem is not steady it arise from time to time
    but i can not relay on it.
    Moshe
    Moshe-A
    09-18-2012 02:11 AM in reply to: scot-65
    Scot,
    i have changed the local variable name and it seems that autocad is pleased with that
    (wonder why in callback a local variable 'filename' is not accepted but 'fname' does -
    undocumented bug?) hope it will stay
    Scot, could you take a look at my other theard TDINDWG v TDUSRTIMER?
    thanks
    Moshe
    *Pro
    scot-65
    09-18-2012 04:04 PM in reply to: Moshe-A
    I'm not sure what is "client_data_tile"?
    It's not set_tile, mode_tile, or action_tile.
    Getting past that, what is "(rkey filename)"? Looks like a call to a subroutine?
    If you want the gremlin to remain inside a program, yet still have access to that
    gremlin while inside a function (subroutine) restructure your program as follows:
    (defun c:MAIN ( / a b c...)
     (defun SUB1 (f g / h k...) ... ) ;a b c f and g can be seen inside here, h and k is local to SUB1.
     (defun SUB2 (m / n...) ... ) ;again, a b c and m can be seen inside here, n is local to SUB2.
     (princ)
    );end MAIN
    One might have conflicts with declared variables (gremlins) for this structure above.
    I have used a suffix "1", "2", etc. inside my subs, especially with numbers or counters
    (sslength, setq n1, etc.).
    TDINDWG Time Display in Drawing I looked at once upon a time,
    but never investigated the other one (is it a Dunsel variable???).
    We use UNNAMED profiles here. It serves us no purpose(?).
