Hi Guys,
i have encounter a problem in callback function...i am using (client_data_file) to attach string (in a list)
to be transfer to callback function. in the callback i set a local variable to get this string and autocad set it
to nil but if i declare the variable as global it works (not sure if it is a steady problem)
does any one seen this or am i missing something?
here is an example of my code:
(setq some_string "abcde") (client_data_tile "accept" "(some_string)") (action_tile "accept" "(ctrl_accept $data)") (defun ctrl_accept (data / str) (setq str (eval (car (read data)))) ; this returns nil (done_dialog 1) ) ; but this one works (defun ctrl_accept (data) (setq str (eval (car (read data)))) ; this returns "abcde" (done_dialog 1) )
thanks in advance
Moshe
Solved by Moshe-A. Go to Solution.
For your first defun you declare a local variable STR which does not leave the
confides of the opening and closing parenthesis of the defun. In other words,
it is a local variable that stays local. If you want it to leave this area, you show
one of the many tricks that are available.
I personally keep the done_dialog on the same line as "accept". It's easier for me to follow...
Try this (untested)
(defun ctrl_accept (data) (eval (car (read data))) )
..."(setq str (control_accept $data))(done_dialog 1)"
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Hi Scot,
thank you very much for your help.
i expand a little of what i'm doing:
suppose in main function i have a registry key and a file name
(that were build in main and ofcourse defined as locals) as the user picks th OK button
i need them in the (ctrl_accept) callback function to write the file name to registry.
all of that include some error cheaking could not be done from (action_tile) call
i suppose you agree with me?!
the problem arise in buttons i use and edit_box tiles.
this code is a small example of my program
(defun ctrl_accept (data / rkey filename) (setq rkey (eval (car (read data))) (setq filename (eval (cadr (read data)))) (if (vl-registry-read rkey) (vl-registry-write rkey "datafilename" filename) ) (done_dialog 1) ) (defun c:main (/ rkey filename dcl_id what_next) (setq rkey (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key) "\\Applications") rkey (strcat rkey "\\AppName") ) (if (not (vl-registry-read rkey)) (vl-registry-write rkey) ) (setq filename "appdata.txt") (setq dcl_id (ai_dcl "appdata")); load dcl file (setq what_next 3) (While (> what_next 1) (if (not (new_dialog "app_dialog" dcl_id "" '(-1 -1))); open dialog (exit) ) (client_data_tile "accept" "(rkey filename)") (action_tile "accept" "(ctrl_accept $data)") (SetQ what_next (start_dialog)); start dialog ); while (princ) )
as i said earlier the problem is not steady it arise from time to time
but i can not relay on it.
Moshe
Scot,
i have changed the local variable name and it seems that autocad is pleased with that
(wonder why in callback a local variable 'filename' is not accepted but 'fname' does -
undocumented bug?) hope it will stay
Scot, could you take a look at my other theard TDINDWG v TDUSRTIMER?
thanks
Moshe
I'm not sure what is "client_data_tile"?
It's not set_tile, mode_tile, or action_tile.
Getting past that, what is "(rkey filename)"? Looks like a call to a subroutine?
If you want the gremlin to remain inside a program, yet still have access to that
gremlin while inside a function (subroutine) restructure your program as follows:
(defun c:MAIN ( / a b c...)
(defun SUB1 (f g / h k...) ... ) ;a b c f and g can be seen inside here, h and k is local to SUB1.
(defun SUB2 (m / n...) ... ) ;again, a b c and m can be seen inside here, n is local to SUB2.
(princ)
);end MAIN
One might have conflicts with declared variables (gremlins) for this structure above.
I have used a suffix "1", "2", etc. inside my subs, especially with numbers or counters
(sslength, setq n1, etc.).
TDINDWG Time Display in Drawing I looked at once upon a time,
but never investigated the other one (is it a Dunsel variable???).
We use UNNAMED profiles here. It serves us no purpose(?).
Scot-65
