Visual LISP, AutoLISP and General Customization
open command in script using a variable
10 REPLIES 10
Message 1 of 11
gcsjlewis
2007 Views, 10 Replies
**Using Autocad Electrical 2011
So here is what i have come up with:
I have 4 lisps, all saved in one file (new_project.lsp)...Not very original but i am just testing
I have them called out as
(defun 120VAC () (my lisp))
(defun 120VAC2 () (my lisp))
(defun 120to24 () (my lisp))
(defun 24vdc2 () (my lisp))
I created a macro calling a script file that i created for each lisp.
^C^C_.script;"t:/acad_autolisps/scripts/New_Project_Scripts/120VAC_Incoming.scr"
^C^C_.script;"t:/acad_autolisps/scripts/New_Project_Scripts/120VAC_Second.scr"
^C^C_.script;"t:/acad_autolisps/scripts/New_Project_Scripts/120VAC_to_24VDC.scr"
^C^C_.script;"t:/acad_autolisps/scripts/New_Project_Scripts/24VDC_Second.scr"
Everything works great. other than one thing.
In my script file I have the following setup:
filedia 0
_.open "t:\acad_autolisps\testing\test_project\000-00-07.dwg"
(load "new_project.lsp" nil)
(if 120vac (120vac))
My question is, is there a way to open a file in a script using a variable i set using the following command
(setq dwgname (car (c:wd_proj_getdwgnam (ace_getactiveproject) 6 0)))
I tried _.open dwgname...but this doesn't work,
I can also put in
 (car (c:wd_proj_getdwgnam (ace_getactiveproject) 6 1)) which if i typed this into the command line it will open the 7th drawing in the project.
Iv'e tried a bunch of various ways that will open the drawing through the command line but not through script.
any ideas on how to make this work??
10 REPLIES 10
Message 2 of 11
hmsilva
in reply to: gcsjlewis
EDITED
was a bad idea
deleted... Smiley Embarassed
Henrique
Message 3 of 11
gcsjlewis
in reply to: hmsilva
I tired messing around with that too.
This is what I get:
Command: (vl-string-translate "\\" "\"" (car (c:wd_proj_getdwgnam
"T:\"Acad_Autolisps\"Testing\"Test_project\"000-00-07.dwg"
I also tried this before
(setq dwgname (car (c:wd_proj_getdwgnam (ace_getactiveproject) 6 0 )))
(vl-string-translate "\\" "\"" dwgname)
Result
Command: (vl-string-translate "\\" "\"" dwgname)
; error: bad argument type: (or stringp symbolp): nil
Or:
(vl-string-translate "\\" "\"" (read dwgname))
Command: (vl-string-translate "\\" "\"" (read dwgname))
________________________________
The information contained in this message is intended only for the personal and confidential use of the recipient(s) named above. If the reader of this message is not the intended recipient or an agent responsible for delivering it to the intended recipient, you are hereby notified that you have received this document in error and that any review, dissemination, distribution, or copying of this message is strictly prohibited. If you have received this communication in error, please notify us immediately, and delete the original message.
Message 4 of 11
Try messing around with this:
(Defun c:foo ()
      (startapp
            (strcat "explorer /select, "
                    (getvar "dwgprefix")
                    (getvar "dwgname")
                    ", /e"))
 and this:
(strcat (getvar "dwgprefix")(getvar "dwgname"))
 HTH
Message 5 of 11
gcsjlewis
I cannot get this too work without opening another session of autocad, and I do not want that to happen because then it doesn't recognize my (car (c:wd_proj_getdwgnam (ace_getactiveproject) 6 0)) command
Message 6 of 11
hmsilva
Try
(vl-string-translate "/" "\\"" (car (c:wd_proj_getdwgnam (ace_getactiveproject) 6 0)))
should work...
HTH
Henrique
Message 7 of 11
gcsjlewis
This doesn't work either.... Here are my results
Command: (vl-string-translate "/" "\\"" (car (c:wd_proj_getdwgnam
("_>
("_> *Cancel*
; error: Function cancelled
Message 8 of 11
hmsilva
("_>
("_> *Cancel*
First of all, sorry manamalewis, I couldn't test it and and had a typo...
what I had thought was
(vl-string-translate "\\" "/" (car (c:wd_proj_getdwgnam (ace_getactiveproject) 6 0)))
at the command line I think it works, in a .scr file, I don't know because at the moment I am out of the office and can't test ...
Henrique
Message 9 of 11
hmsilva
Not the answer you expect, but can be a work around
Untested...
(defun c:MyScr (/ DWGNAME SCR SCRFILE)
  (if (setq dwgname (car (c:wd_proj_getdwgnam (ace_getactiveproject) 6 0)))
    (progn
      (setq scrfile "C:\\Windows\\temp\\MyScr.scr")
      (setq scr (open scrfile "w"))
      (write-line (strcat "filedia\n0") scr)
      (write-line (strcat "_open\n\"" dwgname "\"") scr)
      (write-line "(load \"new_project.lsp\" nil)" scr)
      (write-line "(if 120vac (120vac))" scr)
      (close scr)
      (command "_.SCRIPT" scrfile)
    );; progn
  );; if
  (princ)
);; MyScrcr
HTH
Henrique
Message 10 of 11
gcsjlewis
AWESOME!!! Thanks, I had to modify my lisp/script/macros alittle bit, but it works.  I've read multiple times and places that user input cannot be used across different drawings and using different lisps all rolled into one project but this little bit of code that you did for me solved that problem...  Thanks again
Message 11 of 11
hmsilva
You're welcome!
Glad I could help
Henrique
”Boost
