• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    *The Dark Princess
    object annotation scales BIG AHA!
    119 Views, 0 Replies
    03-30-2010 11:31 AM
    this seems to work on retrun scales for blocks, dims, text and hatches -
    returns nil if no scales found or not annotative.
    you're all welcome to it - I'd love feedback
    most of it is library stuff which I included - thanks to a nice library
    function the actual code is pretty small
    Jamie
    (defun get_obj_scales (en / scales)
    ;-------library functions---------
    (defun jddsubst (ed1 dxf1 newval1)
    (if (= (type ed1) 'ENAME)
    (setq ed1 (entget ed1))
    (if (assoc dxf1 ed1)
    (subst (cons dxf1 newval1)(assoc dxf1 ed1) ed1)
    (reverse (cons (cons dxf1 newval1) (reverse ed1)))
    (defun arctgv (dxf_code list_1)
    (setq list_1 (cond
    ((= (type dxf_code) 'SYM)
    (if (= (type list_1) 'ENAME)
    (vlax-ename->vla-object list_1)
    list_1
    (T
    (if (= (type list_1) 'VLA-OBJECT)
    (vlax-vla-object->ename list_1)
    list_1
    (cond
    ((= (type list_1) 'ENAME)
    (cdr (assoc dxf_code (entget list_1)))
    ((= (type list_1) 'LIST)
    (cdr (assoc dxf_code list_1))
    ((= (type list_1) 'VLA-OBJECT)
    (if (vlax-property-available-p list_1 dxf_code)
    (vl-catch-all-apply 'vlax-get-property (list list_1
    dxf_code))
    nil
    (T nil)
    (defun eng ( x / )
    (if (vl-catch-all-error-p (setq x (vl-catch-all-apply 'entget (list x))))
    nil
    x
    ;----------------main progn------------
    (foreach x (eng (arctgv 350 (arctgv 360 (reverse (eng (arctgv 360
    en))))))
    (if (and (= (car x) 350)
    (setq ed1 (entget (cdr x)))
    (arctgv 340 ed1)
    (setq scales (jddsubst scales (arctgv 300 (arctgv 340 ed1))
    (arctgv 141 (arctgv 340 ed1))))
    scales
    Please use plain text.
