Visual LISP, AutoLISP and General Customization
Distinguished Contributor
CrazyIvan
Message 1 of 17 (852 Views)
naming a single layout tab to match the file name
852 Views, 16 Replies
08-02-2012 01:18 PM
Trying to get the files I use which are single-layout tab files to name the layout tab to match the file name, minus the .DWG extension.
Here is what I am trying to use, but it doesn't seem to be working.
Any help is appreciated.
(DEFUN C:RRT (/ name)
 (setq name (getvar (vl-filename-base (getvar "dwgname"))))
 (command "-layout" "rename" name "")
(princ)
THANKS.
*Expert Elite*
Kent1Cooper
Message 2 of 17 (850 Views)
Re: naming a single layout tab to match the file name
08-02-2012 01:36 PM in reply to: CrazyIvan
You have an extra (getvar) function in there, and the which-layout-to-rename and what-to-rename-it entries reversed.  Try:
 (setq name (vl-filename-base (getvar "dwgname")))
 (command "-layout" "rename" "" name)
 (princ)
or skip the variable, and just do this:
(DEFUN C:RRT ()
 (command "-layout" "rename" "" (vl-filename-base (getvar "dwgname")))
 (princ)
Kent Cooper
CrazyIvan
Message 3 of 17 (840 Views)
08-02-2012 03:19 PM in reply to: Kent1Cooper
Thanks!  I knew something was amiss.  It's been a few years since I've done any LISP, so forgotten skills...
Thanks again!
Active Member
bdcurry
Message 4 of 17 (741 Views)
10-09-2012 01:04 PM in reply to: Kent1Cooper
Is there a way to do this with the sheet name instead of the filename?
*Expert Elite*
Kent1Cooper
Message 5 of 17 (736 Views)
10-09-2012 01:12 PM in reply to: bdcurry
That would depend on how/where the sheet name is stored.  Attribute?  If so, in what Block name, with what Tag?  Text entity?  If so, on what Layer, and/or in what size or style or something to distinguish it from other Text?  Or ask the User to pick it?  Something else?
Kent Cooper
Active Member
bdcurry
Message 6 of 17 (732 Views)
10-09-2012 01:35 PM in reply to: Kent1Cooper
Any of those would work. But since just about all that could change from project to project, i think user pick would work good...
*Expert Elite*
Kent1Cooper
Message 7 of 17 (724 Views)
10-09-2012 02:33 PM in reply to: bdcurry
Something like [minimally tested]:
(defun C:RTT (); = Rename Tab to match Text
  (if (/= (getvar 'ctab) "Model")
    (command ; then
      "_.layout" "_rename" (getvar 'ctab)
      (cdr (assoc 1 (entget (car
        (nentsel "\nSelect Text/Mtext/Attribute to change Layout Tab name to its content: ")
      )))); cdr etc.
    ); command
    (prompt "\nCannot rename Model space tab."); else
  ); if
  (princ)
); defun
Kent Cooper
Active Member
bdcurry
Message 8 of 17 (704 Views)
10-10-2012 06:42 AM in reply to: Kent1Cooper
So it works on attributes but it only renames it with the one line I select. Can it do multiple lines?
And it wouldnt work for text/mtext, it selects the text but doesnt rename the layout.
Thanks.
*Expert Elite*
Kent1Cooper
Message 9 of 17 (698 Views)
10-10-2012 07:05 AM in reply to: bdcurry
I don't have a new-enough version [back in ol' 2004] to have multiple-line Attributes, so I can't help you there.  And for me, it does work with Text and Mtext -- I suppose that difference may also be version-related.  I hope someone else can step in and figure out how to alter it, or maybe work out some entirely different approach.
Kent Cooper
*Expert Elite*
pbejse
Message 10 of 17 (683 Views)
10-10-2012 08:27 PM in reply to: Kent1Cooper
For Multi line Attribute , The first DXF 1 is always "". you can however reverse  the resulting data  (it wouldnt matter for TEXT/MTEXT)
(cdr (assoc 1 (reverse (entget (car
But still you may have to deal with these invalid characters for layout name  "<>/\":;?*|,=`"  might  it be MTEXT,TEXT or ATTRIBUTES. You need to STRIP the resulting string of those characters
HTH
You are not logged in.
Announcements
Need installation help?
Ask the Community
